Upgrade Guide for DB2 UDB for z/OS and OS/390 > Reviewing the Database Upgrade Log Files >
Reviewing Upgrade Log Files for Errors
Upgrades: All upgrades. Environments: All environments. This topic is part of an upgrade process. See How to Perform the Upgrade. Do not proceed with the upgrade until unacceptable errors have been corrected. If you cannot correct the error, contact Siebel Technical Support or Professional Services to report the error in detail. Certain errors, such as a failure to create indexes, can result in performance problems or anomalous behavior in Siebel eBusiness applications. The log files may include errors that are expected and benign. Before you continue with the upgrade, you must compare any error messages found in the log files to a list of acceptable error messages. If you encountered an error during the upgrade, review log files named UpgWiz.log (Windows) or srvrupgwiz1.log (UNIX). The log file is located in the following directory: Windows: SIEBEL_ROOT\log\PROCESS\output
UNIX: $SIEBEL_ROOT/log/PROCESS/output
The name of the log file increments for subsequent log files that are created when the Siebel Upgrade Wizard encounters a problem and the user runs the Siebel Upgrade Wizard again. Review the end of the log file for details about the latest failure. If the step that failed was not a native SQL step (which would be listed in the log file), then it occurred as part of an external utility for which you need to review a corresponding log file, identified by the /L parameter. If the upgrade completed successfully, there are several log files that you can safely ignore:
Related Topics
Troubleshooting Steps 21: How to troubleshoot messages generated while running the Repository Upgrade in Siebel v7, located on SupportWeb
Troubleshooting Steps 28: Errors.rtf -- Siebel version 7.5.3, located on SupportWeb
To manually review the log files for unacceptable errors
- Review the state1.log file to see at what step the upgrade failed. This step can be traced back to the driver file. The state1.log file is located in the following directory:
Windows: SIEBEL_ROOT\log\PROCESS\state
UNIX: $SIEBEL_ROOT/log/PROCESS/state
- Print the
errors file. This file is located in the installation subdirectory for your database platform:
Windows: DBSRVR_ROOT\DATABASE_PLATFORM\errors.rtf or errors.htm
UNIX: DBSRVR_ROOT/DATABASE_PLATFORM/errors.txt
- Sort the files in the following directory by date.
- Open each log file, starting with the earliest, and search for errors.
Log files are identified by the .log extension. Errors are either tagged with the word error or enclosed in square brackets [...].
You must start with the earliest log file to shorten your research time if you find unacceptable errors in an early log file.
- For each error found, compare the error description against the list of acceptable errors documented in the errors
file.
The log files generated by the repository Siebel Upgrade Wizard (for example srvrupgwiz1.log) appear in the errors file as upgwiz1.log, upgwiz2.log, incrementing for additional log files.
- If you find the error in the errors
file, it is acceptable and no action is required. Continue to review the errors found in the log file.
- If an error appears multiple times in a log file, but only one occurrence of that error appears in the errors
file, all errors of that type are acceptable and no action is required. Continue to review the errors found in the log file.
- If a log file is not listed in the errors
file, there are no acceptable error messages for that log file. You must correct the condition that caused the error before you rerun the Siebel Upgrade Wizard.
- If you find an error that is not listed in the errors
file, it is unacceptable. You must correct the condition that caused the error before you rerun the Siebel Upgrade Wizard.
On SupportWeb, navigate to Troubleshooting Steps > Product Areas > Upgrade, and choose Troubleshooting Steps 21. Common errors and how to resolve them are listed in this document. If the error is not listed or you cannot resolve it, contact Siebel Technical Support. Do not proceed with the upgrade.
- Repeat Step 5 for each log file.
