Upgrade Guide for DB2 UDB for z/OS and OS/390 > Upgrading the Database >
Changing the Database Server Configuration Utility Language
Upgrades: All upgrades. Environments: All environments. This topic is part of an upgrade process. See How to Perform the Upgrade. The Database Server Configuration utility launches in the language selected when you ran the Siebel Enterprise System Installer. You can change the language in which the utility runs, if desired, from the language chosen during installation. To change the Database Server Configuration utility language, see the Siebel Installation Guide for the operating system you are using. If you want an additional language to appear in the language list in the Database Server Configuration utility, you first need to install the appropriate language pack on the Siebel Database Server and on the Siebel Server. For information about installing additional language packs, see the Siebel Installation Guide for the operating system you are using. For more information about the Database Server Configuration utility, see About the Database Server Configuration Utility.
