Upgrade Guide for DB2 UDB for z/OS and OS/390 > How the Upgrade Works >
About the Database Server Configuration Utility
Upgrades: All upgrades. Environments: All environments. The Database Server Configuration utility provides a user interface for performing the Siebel Database upgrade. To complete an upgrade, you must run the utility several times, each time in a different mode, as shown in Figure 2.
Figure 2. Database Server Configuration Utility Modes
Development Environment Upgrades
For a development environment upgrade, you run the utility twice, once in each of the following modes:
- upgrep. This mode makes the following changes:
- Drops interface tables and database triggers
- Populates columns that must change from NULL to NOT NULL
- Creates new tables. Merges existing tables.
- Prepares for index creation. Verifies that there are no unique key violations.
- Creates indexes
- Imports seed data
- Imports the Prior V x.x Siebel Repository, New Siebel Repository, and New Customer Repository
- Makes modifications to repository objects to prepare for the repository merge
- Updates primary children foreign key references
- Performs miscellaneous file actions
- upgphys. This mode makes the following changes:
Production Upgrades
For a production upgrade, you run the utility in the following mode:
- upgrep + upgphys. This mode makes the following changes:
- Uses the custrep.dat and schema.ddl files from the development environment upgrade to create new tables and merge existing tables
- Creates indexes
- Imports seed data
- Makes several administrative changes to table data, including updating the schema version in
S_APP_VER. It does not make schema changes.
How SQL Files Are Handled
When you run the Database Server Configuration utility, it does the following:
- Collects configuration information
- Forwards the information to an SQL generator that creates or populates SQL files with the required commands. The SQL generator extracts these commands from an intermediate XML file containing all the SQL commands required for an upgrade.
- Creates an upgrade configuration file (UCF)
- Prompts you to start the Siebel Upgrade Wizard. The wizard uses the UCF file to execute the SQL files and other input files against the Siebel Database.
In some cases, you will need to modify the generated SQL files as required by Siebel Release Notes, Technical Notes, or Siebel Alerts before you run the Siebel Upgrade Wizard. To do this, answer No when prompted to run the Siebel Upgrade Wizard. Then, edit the SQL files and manually launch the Siebel Upgrade Wizard. How To Identify Upgrade Configuration Files
Upgrade configuration files are stored in the following location: Windows: SIEBEL_ROOT\bin
UNIX: $SIEBEL_ROOT/bin
Upgrade configuration files use the following naming convention: master_UPGRADEOPTION_ENVIRONMENT_VERSION.ucf
where:
UPGRADEOPTION = the upgrade process you are performing
- Siebel Database schema upgrade =
upgrep
- Custom database schema upgrade =
upgphys
ENVIRONMENT = the environment that you are upgrading
- Development environment upgrades =
dev
- Production environment upgrades =
prod
VERSION = the version from which you are upgrading
For example, if you are upgrading from Siebel 7.0.4, the UCF file generated from the development environment upgrep is as follows: master_upgrep_dev_704.ucf
Related Topic
About Parameter Validation
The Database Server Configuration Wizard validates certain parameters, and does not proceed if you enter an invalid parameter. The configuration wizard validates the following information:
- That you have renamed the Siebel Repository to Prior Customer Repository
- That tablespaces exist in your database
- That username and password are valid
- That tableowner and tableowner password are valid
- That the language pack is installed
- That the directories chosen exist
