Upgrade Guide for DB2 UDB for z/OS and OS/390 > Upgrading the Database >
Running the Siebel Upgrade Wizard
Upgrades: All upgrades. Environments: All environments. This topic is part of an upgrade process. See How to Perform the Upgrade. The Siebel Upgrade Wizard calls drivers that execute SQL scripts against the Siebel database. These scripts were created or populated when you ran the Database Server Configuration utility. When the Siebel Upgrade Wizard encounters errors that prevent continuing the upgrade, it writes the errors to the log files and stops the upgrade. After you correct the problems causing the errors, you can restart the Siebel Upgrade Wizard. In most cases, the wizard resumes from where it stopped. For more information on the Siebel Upgrade Wizard, see About the Siebel Upgrade Wizard.
