Upgrade Guide for DB2 UDB for z/OS and OS/390 > Upgrading a Database from the Midtier >
Resuming the Siebel Upgrade Wizard After the First Pause
Upgrades: All upgrades. Environments: Development (midtier-centric) environment. This topic is part of an upgrade process. See How to Perform the Upgrade. After the schema has been manually created (after you have performed the task, Executing SQL Files After the First Pause), continue the upgrade from the point at which it paused. To continue upgrade of the Siebel Database schema on the workstation
- Resume the development environment upgrade using the appropriate method for your operating system.
Windows:
- If the dialog box is still open from Step 4, click Yes in the dialog box.
- If you closed the Siebel Upgrade Wizard screen or it is no longer open, restart the upgrade by typing the following command at the Windows DOS command prompt from the
SIEBEL_ROOT\siebsrvr_root\BIN directory:
siebupg.exe /m master_UPGRADEOPTION_ENVIRONMENT_VERSION_mf.ucf
To restart a development upgrade from Release 7.0.4, type the following command:
siebupg.exe /m master_upgrep_dev_704_mf.ucf
UNIX:
- Navigate to $
SIEBEL_ROOT/bin and type the following command:
srvrupgwiz /m master_UPGRADEOPTION_ENVIRONMENT_VERSION_mf.ucf
To restart a development environment upgrade from Release 7.0.4, type the following command:
srvrupgwiz /m master_upgrep_dev_704_mf.ucf
- In the Siebel Upgrade Wizard screen, click OK to resume the upgrade.
A check mark appears beside each item as it is completed.
CAUTION: The upgrade process executes in a DOS command window. Do not click inside this window while the upgrade is running. If you accidentally click inside the DOS command window, the process pauses and the word Select precedes the title of the command window. To continue, press the space bar or escape.
The Siebel Upgrade Wizard stops again and the following message appears:
Pause #2
Please make sure your database administrator performs operations based on the files in the DDL Output Directory to complete this step. Once the operations are completed, please select Yes. To stop now and continue upgrade later, please select No. (To resume, please start the Upgrade Wizard from the command line using option /m master_upgrep_dev_<path>_mf.ucf.)
- Do not click either Yes or No when the second pause message appears. Leave this dialog box open until after your DBA has executed the SQL output files as described in Executing SQL Output Files After the Second Pause.
After successfully executing the SQL files and reviewing the log files for unacceptable errors, continue with the upgrade.
