Upgrade Guide for DB2 UDB for z/OS and OS/390 > Upgrading a Database from the Midtier >
Resuming the Siebel Upgrade Wizard After the Third Pause
Upgrades: All upgrades. Environments: Development (midtier-centric) environment. This topic is part of an upgrade process. See How to Perform the Upgrade. After your DBA has performed the task, Executing SQL Output Files After the Third Pause and updated statistics, you may continue the upgrade from the point at which it paused. CAUTION: Do not proceed unless you installed stored procedures and user defined functions as described in Deploying Stored Procedures and User-Defined Functions.
To continue upgrade of the Siebel Database schema on the workstation
- Resume the development environment upgrade using the appropriate method for your operating system.
Windows:
- If the dialog box is still open from Step 2, click Yes in the dialog box for pause #3.
- If you closed the Siebel Upgrade Wizard screen or it is no longer open, restart the upgrade by typing the following command at the Windows DOS command prompt from the
SIEBEL_ROOT\siebsrvr_root\BIN directory:
siebupg.exe /m master_UPGRADEOPTION_ENVIRONMENT_VERSION_mf.ucf
To restart a development upgrade from Release 7.0.4, type the following command:
siebupg.exe /m master_upgrep_dev_704_mf.ucf
UNIX:
- Navigate to $
SIEBEL_ROOT/bin and type the following command:
srvrupgwiz /m master_UPGRADEOPTION_ENVIRONMENT_VERSION_mf.ucf
To restart a development environment upgrade from Release 7.0.4, type the following command:
srvrupgwiz /m master_upgrep_dev_704_mf.ucf
- In the Siebel Upgrade Wizard screen, click OK to resume the upgrade.
A check mark appears beside each item as it is completed.
