Upgrade Guide for DB2 UDB for z/OS and OS/390 > Upgrading a Database from the Midtier >
Upgrading the Physical Schema
Upgrades: All upgrades. Environments: Development (midtier-centric) environment. This topic is part of an upgrade process. See How to Perform the Upgrade. The configuration utility that you ran in Preparing to Run the Database Server Configuration Utility updated the Siebel Database Schema. You must now use the Database Server Configuration Wizard to apply these changes to the physical database schema to upgrade it to the new version. The repository on which you run the Physical Schema upgrade must be the same repository that you prepared for the merge. To launch the Database Configuration Wizard, refer to one of the following procedures as appropriate for your operating system:
