Upgrade Guide for DB2 UDB for z/OS and OS/390 > Upgrading the Database >
Running the Database Server Configuration Utility Under Windows
Upgrades: All upgrades. Environments: All environments. Platforms: Windows only. This topic is part of an upgrade process. See How to Perform the Upgrade. Run the Database Server Configuration utility to upgrade the Siebel Database. The utility collects information, populates a master configuration file, and calls the SQL generator to create SQL commands. The Siebel Upgrade Wizard then uses the configuration file and SQL commands to upgrade the Siebel Database. For more information on the Database Server Configuration utility, see About the Database Server Configuration Utility. Prerequisite: Collect the information that the Database Server Configuration utility requires. See Preparing to Run the Database Server Configuration Utility. To run the Database Server Configuration utility under Windows
- Verify that no server tasks are running in the background.
If necessary, stop Siebel Servers and Siebel Gateway Name Server service by navigating to Start > Settings > Control Panel > Services.
- Select Start > Programs > Siebel Enterprise Servers 7.x > Configure DB Server.
The first window of the Database Server Configuration utility appears.
- Enter the information requested in each window and click Next.
To return to previous windows, click Previous.
- When the runnow window displays, do the following:
- Upgrep mode: Answer No. Do not start the Siebel Upgrade Wizard.
- Upgphys mode: Answer Yes to start the Siebel Upgrade Wizard.
Just before displaying the runnow window, the Database Server Configuration utility calls the SQL generator to create or populate SQL scripts.
To manually start the Siebel Upgrade Wizard, see Running the Siebel Upgrade Wizard.
