Upgrade Guide for DB2 UDB for z/OS and OS/390 > Preparing a Development Environment for Upgrade >
Prerequisites for a Development Upgrade
Upgrades: All upgrades. Environments: Development environment only. Before you upgrade your development environment, make sure that the development database configuration meets the database requirements outlined in Verifying Database Server Configuration, and meets the requirements depicted in the Siebel Installation Guide for the operating system you are using. If your development environment platform is DB2 UDB for Windows and UNIX, see Upgrade Guide. NOTE: Make sure that the development database uses binary sort order. Production databases are not constrained by this requirement.
If you have not already done so, copy the Upgrade Planning Worksheet, located in Upgrade Planning Worksheet and fill out the appropriate fields with the following information.
