Bookshelf Home
Contents
Index
PDF
Upgrade Guide for DB2 UDB for z/OS and OS/390
Preparing a Development Environment for Upgrade
This chapter contains the following topics:
Prerequisites for a Development Upgrade
About Moving Tables
Checking In Development Repository Projects
Saving Interface Table Data
Upgrading Your DB2 Software
Preparing EIM Tables for Upgrade
Preparing for Intersection Table Maintenance and Deduplication
Determining Which Template File was Used During an Extract or Merge
Disabling Customized Triggers
Dropping Customized Views
Preparing the Development Environment Repositories for Upgrade
