Upgrade Guide for DB2 UDB for z/OS and OS/390 > Preparing a Development Environment for Upgrade >
Upgrading Your DB2 Software
Upgrades: All upgrades. Environments: Development environment only. Before you upgrade, carefully review System Requirements and Supported Platforms on Siebel SupportWeb to verify that you are using the currently supported versions of DB2 software.
- DB2 Version 7. If you are using an unsupported version of DB2, you must migrate to and thoroughly test the currently supported version before you upgrade to Siebel 7.7. You should perform your DB2 version upgrade on a separate subsystem from the one that you plan to use for Siebel 7.7. Plan to allow at least two weeks of testing to verify that your DB2 upgrade was successful before you proceed with the upgrade of your Siebel Database.
- DB2 Connect. Siebel Dedicated Web Clients (Siebel Mobile Web Client in connected mode) and Siebel Servers communicate with DB2 UDB for z/OS through DB2 Connect middleware. Verify that you are using the version of DB2 Connect supported for Siebel 7.7.
NOTE: Make sure that all software meets the requirements specified in System Requirements and Supported Platforms on Siebel SupportWeb.
