Upgrade Guide for DB2 UDB for z/OS and OS/390 > Preparing a Development Environment for Upgrade >
Determining Which Template File was Used During an Extract or Merge
Upgrades: All upgrades. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform the Upgrade. This section describes how to determine which template file that was used for an extract/merge when a storage control file is created. To determine the template file that was used for an extract/merge
- Open the
dbextract.log file and review the command line that was entered.
- Check the value for the /i parameter. You can also check the
upgwiz.log file for the strgxtrct.exe command string.
/i D:\18025\dbsrvr\db2390\storage_p_e.ctl
2004-01-28 09:10:32D:\18025\siebsrvr\bin\strgxtrct.exe /u QADMIN /p ***** /c Q10K /d CQ10K029 /l D:\18025\siebsrvr\log\dbconfig_extract_merge_mf_lk5\output/dbextract.log /i D:\18025\dbsrvr\db2390\storage_p_e.ctl /o D:\18025\dbsrvr/db2390/SStempstore.txt /v D:\18025\dbsrvr/db2390/override.inp /8 D029 /9 SIEBTS /1 SYSDEFLT /2 SYSDEFLT /3 BP1 /4 BP2 /7 EBCDIC
