Upgrade Guide for DB2 UDB for z/OS and OS/390 > Preparing a Development Environment for Upgrade >
Disabling Customized Triggers
Upgrades: All upgrades. Environments: Development environment only. Release 7.7 does not support customized triggers. If you have created customized triggers on your Siebel base tables, disable them before you perform the upgrade. You must recreate them after the upgrade is finished.
