Upgrade Guide for DB2 UDB for z/OS and OS/390 > Preparing a Development Environment for Upgrade >
Dropping Customized Views
Upgrades: All upgrades. Environments: Development environment only. If you created customized views on Siebel base tables, you must drop them before you perform the upgrade. If they are still applicable after the upgrade, you must recreate them after the upgrade is finished.
