Upgrade Guide for DB2 UDB for z/OS and OS/390 > Upgrading a Database from the Mainframe > Preparing the Schema and JCL Files on the zSeries Host >
Unpacking the Unload and Load Control Cards and Executing the DDL
Complete the following procedure to unpack the unload and load cards and execute the DDL. To unpack, unload/load, and execute the DDL
- On the Siebel Upgrade Main Menu, select option 3: SCHEMA/JCL - BUILD DDL AND JCL-PREP FOR UPGRADE.
The SCHEMA/JCL MENU appears. The panel ID is SBLUPGP.
- On the Schema/JCL Menu, select option 1: PDS/SCHEMA/VERIFICATION UTILITIES.
The Utilities Menu appears.
- On the Utilities Menu, select option 0: BUILD/POPULATE UNLOAD/LOAD PDS DATASETS (UNPACK02).
This places you in edit mode for PDS dataset member: DSNHLQ.SIEBEL.INSTALL.JCL(UNPACK02).
- Run the job using the JCL in dataset:
This job populates (unpacks, using IEBUPDTE) the unload and load control cards into members in their corresponding PDS dataset. The DDL files are output (using IEBGENER) to sequential files.
- Verify that the job ran successfully, RC=0.
The JCLTEST return code should be FLUSH.
- After submitting the job, enter
cancel on the command line or press PF3 to save changes.
- After the batch unpack02 (option 0) job has run successfully, select option 1: CUSTOMIZE UNLOAD/LOAD FOR TABLES W/CLOB COLUMNS (CLOBCOPY).
If the source system has no CLOB columns on any tables, one of two message types appears:
DSNHLQ.SIEBEL.INSTALL.JCL(CLOBCOPY)
- Submit the job and verify that it ran successfully, RC=0.
- On the Utilities Menu, select option 2: CREATE DB2 SCHEMA (DB, TABLESPACE, TABLE, UNIQUE INDEXES, VIEW).
This places you in edit mode for PDS dataset member: DSNHLQ.SIEBEL.INSTALL.JCL(SCHEMA01).
NOTE: You need to verify the DDL before running the following job.
NOTE: Verify that the DDL creation (the job submitted in Step 9) was successful before continuing with the upgrade.
- Select option 3: CREATE TEMP/WORK TABLE SCHEMA (3 SETS: TMPTAB00, 01 AND 02).
A message that describes the process for creating the Temp-Tables appears. This process involves being placed in edit mode three times on different PDS TMPTABnn members in the INSTALL.JCL library:
- TMPTAB00
- TMPTAB01
- TMPTAB02
You receive an edit-mode message each time this process occurs. After accepting the message, run a batch job.
The messages have the following format:
1. YOU WILL NOW BE PLACED IN EDIT MODE FOR TMPTAB00 ...PRESS ENTER TO CONTINUE.
- At the edit-mode message for TMPTAB00, press Enter.
This places you in edit mode for PDS dataset and member DSNHLQ.SIEBEL.INSTALL.JCL(TMPTAB00).
- Run this job using the JCL in dataset
This job creates COMMON temp tables used by upgrade data migration SQL scripts.
- At the edit-mode message for TMPTAB01, do the following:
- Press Enter.
This places you in edit mode for PDS dataset and member: DSNHLQ.SIEBEL.INSTALL.JCL(TMPTAB01).
This job creates a log table used by the upgrade process to log Unload jobs on the source subsystem. This table is used only if you are using Siebel Logging and Scheduling.
- At the edit-mode message for TMPTAB02, do the following:
- Press Enter.
This places you in edit mode for PDS dataset and member: DSNHLQ.SIEBEL.INSTALL.JCL(TMPTAB02).
This job creates a log table used by the upgrade process to log selected target subsystem jobs. This table is used only if you are using Siebel Logging and Scheduling.
