Upgrade Guide for DB2 UDB for z/OS and OS/390 > Upgrading a Database from the Mainframe > Executing the Upgrade on the zSeries Host (Phase 2 of 2) >
Loading Target Siebel Log Tables
Perform the following procedure to load target Siebel log tables. This job loads logging records for the new schema indexes (GEN PRIMARY indexes). To load target Siebel log tables
- If you are not on the Siebel Upgrade Main Menu, enter the following command:
TSO SBLUPG77
- Select option 4: UPGRADE - RUN UPGRADE/POST-UPGRADE MAINTENANCE.
The Siebel Upgrade Job Submission Menu appears.
- For Siebel eBusiness application upgrades, the panel ID is SBLRUNHP.
- For Siebel Industry application (SIA) upgrades, the panel ID is SBLRUNFP.
- Select the option for the application you are upgrading.
- Run the job using the JCL in dataset
DSNHLQ.SIEBEL.INSTALL.JCL(LTARLOG2).
After the job is run, verify that the job ran successfully. (RC=0 or RC=4 indicates that the job was successful.)
- After submitting the job, enter
cancel on the command line or press PF3 to save changes.
- Load the target Siebel log table using logload file
DSNHLQ.SIEBEL.JOBLOG.LOADFILE.
- Verify that the job completed successfully (RC=
0 or RC=4).
Jobs with an ABEND (end abnormally) U99 or U099 message are jobs that failed.
If you selected Siebel-Scheduled Mode, this job is logged (as Completed Successfully or Failed) to the target Siebel log table: TARGET_TABLEOWNER.TMP_SBLLOG_TAR.
NOTE: You must fix any failed jobs before proceeding with the upgrade. For information on restarting failed jobs, see Running the Siebel Upgrade Wizard.
