Upgrade Guide for DB2 UDB for z/OS and OS/390 > Performing the Siebel Tools Repository Merge >
Moving the Repository Files
Upgrades: All upgrades. Environments: Production environment only. This topic is part of an upgrade process. See How to Perform the Upgrade. Before doing the production upgrade, you must copy the upgraded repository definition files (schema.ddl and custrep.dat) from the development environment to the production environment. Prerequisite: If you modified repository objects or schema definitions after completing the development upgrade (upgphys), you must regenerate the schema.ddl and custrep.dat files. See Regenerating the Repository Definition Files. To move the repository files
- In the development environment, navigate to the following directory:
Windows: DBSRVR_ROOT\Platform
UNIX: DBSRVR_ROOT/Platform
Where:
Platform is the database platform, for example DBSRVR_ROOT\DB2UDB.
- Copy the following files:
custrep.dat
schema.ddl
- In the production environment, put these files in the following location:
