Bookshelf Home
Contents
Index
PDF
Upgrade Guide for DB2 UDB for z/OS and OS/390
Performing the Siebel Tools Repository Merge
This chapter contains the following topics:
About Inheriting Upgrade Behavior
About the Postmerge Utilities
About the Incorporate Custom Layout (ICL) Upgrade Option
Configuring Objects to Inherit Upgrade Behavior
Renaming the Tools Repository
Migrating Repository Objects to the Standard UI
Running the Repository Preparation Wizard on Release 6.x Repository
Performing a Repository Merge
Determining if a Repository Merge was Successful
Reviewing Attribute Conflicts in the Repository Merge
Reviewing Deleted Objects in the Repository Merge
Reviewing Obsolete Objects in the Repository Merge
Reviewing Customized Business Components
Generating EIM Temporary Columns After a Repository Merge
Regenerating the Repository Definition Files
Deleting Unneeded Repository Files
Safeguarding the New Custom Repository Export File
Moving the Repository Files
Creating a New SRF File
