Upgrade Guide for DB2 UDB for z/OS and OS/390 > Performing the Siebel Tools Repository Merge >
Reviewing Obsolete Objects in the Repository Merge
Upgrades: All upgrades. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform the Upgrade. Objects that were available in the Prior Siebel Repository but are not available in the New Siebel Repository are obsolete. After performing the repository merge, you can generate a list of obsolete objects using Siebel Tools. Objects that were available in the Prior Siebel Repository are compared with the objects that are available in the New Siebel Repository. Prerequisite: The repository merge must have been successful. See Determining if a Repository Merge was Successful. To generate a list of obsolete objects
- In Siebel Tools, navigate to Screens > Application Upgrader > Application Upgrade Object List.
- In the Application Upgrades list, select the record of the successful merge.
- Click Query.
- Enter your query criteria in the Object Differences list:
- Click in the In Prior Standard field so that a check mark appears.
- Click in the In New Standard field so that a check mark appears. Then click in the field again so that no check mark appears.
- Click in the In Prior Customized field so that a check mark appears.
- Click in the Attribute field so that a check mark appears. Then click in the field again so that no check mark appears.
- Press Enter to run the query.
All obsolete objects appear in the Object Differences list. You can filter the objects displayed by using the Top Parent Type and Object Type fields.
- Review the list carefully to determine that obsolete objects that have been deleted will not have an adverse effect on upgraded applications.
