Upgrade Guide for DB2 UDB for z/OS and OS/390 > Performing the Siebel Tools Repository Merge >
Renaming the Tools Repository
Upgrades: All upgrades. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform the Upgrade. Your upgrade will encounter errors if you have more than one existing repository for a development upgrade. Export and archive any redundant repositories from your environment before you upgrade your development environment. To prevent a naming conflict, before you run the upgrade, you must rename your existing development repository (Siebel Repository) to Prior Customer Repository. After the upgrade, your new development repository is given the name Siebel Repository. When you rename the repository, you may prefix the name with additional characters (except for a leading space). Do not append the repository name with additional characters, because this results in an error. To rename the repository
- Start Siebel Tools and connect to the Siebel Database.
Use the version of Siebel Tools for the Siebel release from which you are upgrading.
- If you archived repository objects as .sif files, and you want to have them available in your application, import these archive files back into the repository.
If you do not check these objects back into the repository, they will not be upgraded. You need only to check in those archived objects that you need in the future and want to have available in your upgraded application.
- Choose View > Options.
- Click the Object Explorer tab.
The Object Explorer hierarchy displays.
- Locate Repository in the list, put a check mark in the adjacent box, and then click OK.
This exposes the repositories.
- In the Object Explorer, click the Types tab, and then Click Repository.
- In the Repositories list view, verify that your existing repositories do not use the names reserved for the upgrade process:
- New Customer Repository
- New Siebel Repository
- Prior v6.x Siebel Repository
- Locate your current Siebel Repository in the list applet.
- Click on the name and change it to
When you rename the repository, you may prefix the name with additional characters (except for a leading space, which causes the validation to fail).
For more information about renaming repositories, see Configuring Siebel eBusiness Applications.
TIP: Prefix the repository name with a date; for example, 20031202 Prior v6.x Customer Repository.
- Step off the list to commit the record to the database.
If the validation check fails, verify that the repository name is not prefixed with a leading space.
If no repository is named Prior Customer Repository, the upgrade process renames the Siebel Repository to Prior Customer Repository.
