Upgrade Guide for DB2 UDB for z/OS and OS/390 > Performing the Siebel Tools Repository Merge >
Generating EIM Temporary Columns After a Repository Merge
Upgrades: All upgrades. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform the Upgrade. The repository merge process does not preserve EIM processing columns for custom mappings. After the completion of a successful merge, you must generate the missing custom EIM processing columns in the New Customer Repository. Prerequisite: The repository merge must have been successful. See Determining if a Repository Merge was Successful. To generate EIM temporary columns
- In Siebel Tools, select File > Open Repository, and choose New Customer Repository.
- Navigate to Tools > Upgrade > Generate EIM Processing Columns.
A dialog box displays.
- In the dialog box, click OK to generate EIM processing columns for custom mappings.
- In the Object Explorer window, choose New Customer Repository and verify that the Comment field shows
UpgEimCol.
This indicates that the EIM temporary columns were created successfully.
