Upgrade Guide for DB2 UDB for z/OS and OS/390 > Application Upgrade Planning >
Upgrade Planning for Handheld Devices
Upgrades: Releases 7.0.x, 7.5.x. Device operating system support, third-party product support, and application configuration management for handheld devices were revised in Release 7.7. Before the upgrade, verify that handheld devices are running an OS supported by Release 7.7. Also, verify that third-party software is the correct version. After the upgrade, you must enter any handheld device-related application configuration changes into the handheld device administration screen. Supported Device OS
The 2002 version of the Pocket PC operating system is no longer supported as of Release 7.7. Devices running Pocket PC 2002 must be upgraded to Pocket PC 2003. For a full description of supported handheld devices and operating systems, see System Requirements and Supported Platforms on Siebel SupportWeb. Active Sync Support
The third-party product Active Sync must be at version 3.7.1 or higher as of Release 7.7. For a complete description of supported third-party products, see System Requirements and Supported Platforms on Siebel SupportWeb. Handheld Device Administration
Release 7.7 introduced a handheld device administration screen. If you have modified the PDA portion of the Siebel Sales, Siebel Service, Siebel ePharma, or Siebel eConsumer application .cfg file, do the following before upgrading:
- Save the modified .cfg file under a new name so that it is not overwritten during the upgrade.
- After the upgrade, go to the Administration—Mobile screen and enter the changes from the saved .cfg file. For information on using this screen, refer to the Handheld guide for your application.
Handheld Application Upgrade
Handheld applications do not upgrade automatically. Users must uninstall the application and install Release 7.7.
