Bookshelf Home
Contents
Index
PDF
Upgrade Guide for DB2 UDB for z/OS and OS/390
Running the Postmerge Utilities
This chapter contains the following topics:
Troubleshooting Postmerge UI Problems
Verifying Business Address Applet Configuration
Reviewing Grid-Based Applets After the Merge
Reviewing UI Navigation After the Merge
Reviewing Multi-Value Group (MVG) Shuttle Applets After the Merge
Revising Rich Text Controls After the Merge
Reviewing New Aggregate Categories After the Merge
Revising Visibility Filters to Display Correctly After the Merge
Assigning a Category and Type to Chart Views After the Merge
Assigning a Category and Type to Explorer Views After the Merge
Setting Up Navigation to Inaccessible Detail Views After the Merge
Eliminating Obsolete UI Fields After the Merge
Reviewing UI Objects Affected by ICL After the Merge
Reviewing Required Fields in the UI After Merge
Setting Label Alignment for Text Fields
Assigning an Item Identifier to Web Template Items
