Upgrade Guide for DB2 UDB for z/OS and OS/390 > Running the Postmerge Utilities >
Setting Label Alignment for Text Fields
Upgrades: Release 7.x using ICL. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform the Upgrade. If you selected Incorporate Custom Layout (ICL) for the repository merge and chose Label On Top, you must edit the style sheet (main.css) to set label alignment. To set label alignment for text fields
- Using a text editor, open the main.css file in the Siebel Tools installation directory:
Windows: \public\<lang>\files\main.css
UNIX: /public/lang/files/main.css
where
lang is the installed language, for example enu.
- Search for mceLabel2.
This is a section containing several entries. Verify that the section begins .mceLabel2, not .mceLabel.
- In the .mceLabel2 section, set the following values as shown:
vertical-align : top
text-align:left
font-weight : bold
- Save the file and exit.
