Upgrade Guide for DB2 UDB for z/OS and OS/390 > Basic Database Preparations >
Reviewing Tablespace Size
Upgrades: All upgrades. Environments: Development environment only. Certain tables require larger tablespaces in Release 7.7 to accommodate additional columns. Review each table listed in Table 11 and verify that the page size is sufficient to accommodate new columns. NOTE: It is recommended that you validate the storage control file particularly where you have schema changes.
Specify an entry in the storage control file for each obsolete table and extended table that you want to move to the 1:1:1 model. The 1:1:1 model was new in Release 7.7. For more information, see Planning Your Upgrade. NOTE: You must move S_EMPLOYEE to a 16-KB bufferpool before performing an upgrade because an additional column is added to this table by the upgrade. S_EMPLOYEE has no default tablespace name, because it is obsolete.
Drop all views (including custom views) on a table before you move it.
Table 11. Tables with Additional Columns
S_ASSET
H0477000 |
16 KB |
S_COLUMN
H0658000 |
16 KB |
S_EMPLOYEE
H0997000 |
16 KB |
S_CRSE_URL
H0738000 |
16 KB |
S_DD_TRGT_GRP
H0875000 |
16 KB |
S_IC_CALC_IT
H1158000 |
16 KB |
S_PART_RPR
H1523000 |
16 KB |
S_PERF_MGR_APPR
H1534000 |
16 KB |
S_PROD_DEFECT
H1626000 |
16 KB |
S_PROD_INT
H1639000 |
16 KB |
S_SCHMST_DBSCPT
H1808000 |
32 KB |
S_SRC_PAYMENT
H1894000 |
16 KB |
S_SRV_REQ1_FNX
F2689000 |
16 KB |
S_SRV_REQ1_FNXM
F2690000 |
16 KB |
S_TABLE
H1966000 |
16 KB |
S_UPG_KITWIZ
H2009000 |
16 KB |
NOTE: Certain tables listed in Table 11 may not have existed in the schema during previous releases.
Table 12 lists the EIM tables that need to be evaluated for sufficient tablespace size.
Table 12. EIM Tables with Additional Columns
EIM_ACCOUNT
H0004000 |
32 KB |
EIM_ADDR_PER
H0019000 |
16 KB |
EIM_AGREE_DTL
H0022000 |
16 KB |
EIM_AGREEMENT1
H0021000 |
32 KB |
EIM_ASSET_DTL
H0033000 |
16 KB |
EIM_BASELN_DTL
H0041000 |
16 KB |
EIM_CALL_LST
H0046000 |
32 KB |
EIM_CONSUM_DTL
H0064000 |
16 KB |
EIM_CONTACT
H0065000 |
32 KB |
EIM_CONTACT1
H0066000 |
32 KB |
EIM_COURSE
H0073000 |
32 KB |
EIM_ENTLTMPL
H0121000 |
16 KB |
EIM_FN_ASGNGRP
F2300000 |
16 KB |
EIM_FN_PAYEE1
F2346000 |
16 KB |
EIM_FN_PAYEE2
F2347000 |
16 KB |
EIM_FN_REVN1
F2357000 |
32 KB |
EIM_GROUP
H0147000 |
16 KB |
EIM_IC_INCENTV
H0153000 |
16 KB |
EIM_MDF_DTL
H0181000 |
16 KB |
EIM_ORDER
H0198000 |
32 KB |
EIM_ORDER1
H0199000 |
16 KB |
EIM_ORDER_ITEM
H0201000 |
32 KB |
EIM_ORDER_SHIP
H0203000 |
16 KB |
EIM_PAYMENT
H0215000 |
32 KB |
EIM_PAYMNT_DTL
H0216000 |
16 KB |
EIM_PDSHIP_DTL
H0219000 |
16 KB |
EIM_PL_ITM_DTL
H0228000 |
16 KB |
EIM_PRODINVLOC
H0249000 |
16 KB |
EIM_PRSP_CON
H0271000 |
32 KB |
EIM_PT_RPR_DTL
H0276000 |
16 KB |
EIM_QUO_IT_DTL
H0286000 |
16 KB |
EIM_QUOTE1
H0281000 |
16 KB |
EIM_QUOTE_IT
H0283000 |
32 KB |
EIM_SRC1
H0301000 |
16 KB |
EIM_SRC2
H0302000 |
16 KB |
EIM_SRC_DBM
H0303000 |
16 KB |
EIM_SRC_EVT
H0305000 |
32 KB |
EIM_TARGET_DTL
H0317000 |
16 KB |
