| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Product Administration Guide > Configuration Rule Assembly Language >
Rule Examples
This section contains examples of how to use the eConfigurator Rule Assembly Language to create rules. Some of the rules show item names consisting of both the product name and its configuration ID (Cfg ID).
Basic Rules
The following table shows how create basic rules using Rule Assembly Language.
Boolean and Comparison Operators
The following table shows how to create rules using Boolean and comparison operators.
Rule Template Translations
Table 47 shows examples of the rule templates translated into Rule Assembly Language.
Product Administration Guide Published: 23 June 2003 |
