| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Product Administration Guide > Technical Reference > eConfigurator API >
APIs to Interact with Conflicts and Messages
NOTE: The APIs in this section apply only to customizable products with constraint rules.
GetDetailedReqExpl
This method retrieves conflict messages.
Input Arguments:
- ObjId—the unique identifier of the complex object root (for example, Quote ID).
- RootId—the unique identifier of the complex object root (for example, Quote Line Item row Id).
- IntObjName—the name of the integration object.
Output Arguments:
Expl#—the explanations for the conflicts. Substitute a number for #, such as Expl0, Expl1, and so on.
GetExplanations
This method retrieves configuration explanations for an item.
Input Arguments:
- (Optional) Version—Version arguments are used only when testing a customizable product version that is different from the currently released version.
- Path—the path of the item.
Output Arguments:
The property set returned will have child property sets, each with the property Value as the explanation, as follows:
<Output>
<Expl Value="Explanation"/>
</Output>
GetSignals
This method retrieves configuration engine signals.
Input Arguments:
- (Optional) Path—the integration ID where the item gets signals.
Output Arguments:
The property set returned will have child property sets, as follows:
<Signal Expl="signal"/>
RemoveFailedRequests
This method removes all failed requests sent to the configuration engine.
Input Arguments:
Output Arguments:
None.
UndoLastRequest
This method removes the last request sent to the configuration engine.
Input Arguments:
Output Arguments:
None.
Product Administration Guide Published: 23 June 2003 |
