| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Product Administration Guide > Technical Reference > eConfigurator API >
APIs to Set Product and Attribute Values
This section describes APIs used for setting product and attribute values.
AddItem
This method adds an item to a specified port, creating a new instance of an item. If you want to change the quantity of an existing instance of an item, use SetItemQuantity.
Input Arguments:
- ObjId—the unique identifier of the complex object header.
- RootId—the unique identifier of the complex object root.
- (Optional) Version—Version arguments are used only when testing a customizable product version that is different from the currently released version.
- (Optional) AutoResolve—automatically resolves port cardinality violations. The default is N.
- Prod Item Id—the ID of the item (for example, ORIG_ID in S_PROD_ITEM table).
- Name—the name of the item.
- Product Id—the product id in S_PROD_INT table.
- Port Item Id—the ID of the item's port (for example, ORIG_ID of the port in S_PROD_ITEM table).
- Quantity—the item quantity.
- List Price—the item list price from Pricing Manager, which can be empty.
- Current Price—the current price from Pricing Manager, which can be empty.
- Parent Path—the path of the parent item the port belongs to.
Output Arguments:
None.
CopyInstance
This method copies an instance.
Input Arguments:
- ObjId—the unique identifier of the complex object header of the source instance.
- RootId—the unique identifier of the complex object root of the source instance.
- DestObjId—the unique identifier of the complex object header of the destination instance.
- IntObjName—the name of the integration object specified in Siebel Tools.
Output Arguments:
None.
RemoveItem
This method removes an item from the instance.
Input Arguments:
- Path—the path of the item.
Output Arguments:
None.
RepriceInstance
This method updates the instance with values from the Pricing Manager service. A call to the Pricing Manager service's CalculatePriceCX method returns a property set that is the input to this method.
Input Arguments:
The input property set has child property sets containing the repricing information. The format of the input property set is as follows:
< ObjId="value" RootId="value" Version="value" >
< IntId="integration id" FieldName="value"... FieldName="value" >
In this context, the Integration ID is used to retrieve the instance item.
Output Arguments:
None.
SetAttribute
This method sets the value of an item's attribute.
Input Arguments:
- ObjId—the unique identifier of the complex object root.
- Path—the path of the item with attribute to set.
- Value—the attribute value.
- Name—the attribute name.
- XA Id—the extended attribute ID. This is the row ID of the attribute in the XA Attribute business component.
- Property Type Code—the attribute type.
Output Arguments:
None.
SetItemQuantity
This method sets the quantity of an item.
Input Arguments:
- Quantity—the quantity to set.
Output Arguments:
None.
SetFieldValue
This method updates the value of a field in a line item.
Input Arguments:
- Path—The Integration Id of the line item (or of the parent line item in the case of an attribute).
- FieldName—The field name. This should not be a field that is used and controlled by the Configurator (such as: Quantity, Port Item Id, Integration Id, Attribute Value, and so on).
- XA Id—(Optional) The attribute Id. Specify only if you are setting the value in an attribute field.
- Value—The value of the field.
Output Arguments:
None.
Product Administration Guide Published: 23 June 2003 |
