| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Product Administration Guide > Technical Reference >
Specifying Keep Alive Time for Configurator Sessions
By default, product configurator sessions remain active indefinitely. They do not time out.
You can specify how long product configurator sessions remain active by setting the server parameter for Keep Alive Time. This parameter specifies the time in seconds that a session can remain idle before the session is timed out. The default value of -1 means that the session can remain idle indefinitely and will not be timed out. Table 50 shows this server parameter.
Product Administration Guide Published: 23 June 2003 |
