| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Upgrade Guide for UNIX > Postupgrade Tasks >
Next Steps After Postupgrade Tasks
After you complete the postupgrade tasks, follow the instructions below for the environment you are upgrading:
- Development Environments. Go to Migrating Client Configurations. If you are upgrading from Release 7.x, you do not need to migrate the client configuration; proceed to Preupgrade Tasks to begin preupgrade tasks for the production environment.
If you choose to migrate the Client configuration to the Web Client after upgrading your production environment, (instead of migrating the client configuration after your development environment upgrade), go to Preupgrade Tasks to begin preupgrade tasks for the production environment.
- Production Environments. Go to Migrating Client Configurations. If you completed migration of the client configuration to the Web Client as part of the development environment upgrade, you have completed post upgrade tasks and should thoroughly test your upgraded configuration.
NOTE: You only need to migrate the client configuration to the Web Client if you are upgrading from Release 6.x.
Upgrade Guide for UNIX Published: 20 October 2003 |
