| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Siebel Wireless Administration Guide For Financial Services > Using Siebel Wireless > Entering Text >
Clearing Text
If you make a mistake and want to delete a character, use the clear command provided by the mobile device and browser. For example, the right soft key may work like a backspace key, deleting the character before the cursor.
Siebel Wireless Administration Guide For Financial Services Published: 18 April 2003 |
