| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Siebel Wireless Administration Guide For Financial Services > Using Siebel Wireless > Personalizing Your Wireless Device >
Record Order
The Record Order form lets you establish the sort order of data displayed for each of the main menu links. To change the sort order, use the following fields:
- Applications. Select the Siebel Wireless application for which you want to define sorting. For example, if you are using Siebel Wireless as a field service engineer, select Siebel Service Wireless.
NOTE: The application names in the Applications drop-down list can be configured by your system administrator. If your company has changed the names of the applications in the drop-down list, select the name of the Siebel Wireless application you use.
- Main Menu Links. Select one of the main menu links from the drop-down list. The selection you make in this box determines what is displayed in the Fields box. For example, if you select the Activity link, the activity fields become available in the Fields box.
- Fields. Select the field you want to use for sorting records. For example, to sort activities by Activity Status, select the Activity Status field.
- Sort Order. Select Ascending or Descending for the selected field to determine the sort order of the records.
- Save or Reset. When you have finished personalizing the sort orders, click Save to keep the changes or click Reset to return to the default settings.
The changed sort order settings take effect after you have stepped off the current record.
Siebel Wireless Administration Guide For Financial Services Published: 18 April 2003 |
