| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Siebel Wireless Administration Guide For Financial Services > Using Wireless Banking and Brokerage >
Applications
Use the Applications view to see information about current applications for loans, credit cards, and so forth.
When you select Applications from the main menu, your device displays the Applications view.
The Applications view displays the application title, product name, and stage of the first few of your applications-in-progress. The actual number of applications displayed depends on the configuration settings.
Siebel Wireless Administration Guide For Financial Services Published: 18 April 2003 |
