| Oracle® Retail Predictive Application Server Administration Guide for the Fusion Client Release 14.1 E59119-01 |
![]() Previous |
![]() Next |
Many RPAS utilities can be used for finding information about the different components of a domain or domain data. The following utilities are used solely for retrieving information and are not used to make any changes to a domain or to data in a domain.
The domaininfo utility is used to provide miscellaneous details about a domain, such as the type of domain (simple, master, or sub/local), and the upgrade/version history of the domain.
domaininfo -d pathToDomain [Command] domaininfo -expectedversion
Note: Domain path (-d) is required for all options except the-expectedversion. |
Table 12-1 provides descriptions of the arguments used by the domaininfo utility.
Table 12-1 Arguments Used by the domaininfo Utility
| Argument | Description |
Indicates the path to the domain. Required for all options except |
-domainversion |
Displays the RPAS version of the specified domain. |
-expectedversion |
Displays the expected RPAS version of the domain that the utility expects to find. |
-type |
Displays the type of the domain. Possible values are Simple, Global, and Sub. A Simple domain is a traditional, non-partitioned (non-global) domain. A Global domain is the central or master domain of a global domain environment. A Subdomain is one local domain in a global domain environment that can contain one or more partitions. |
-apptag |
Displays the application associated with domain. |
-history |
Displays the version history of the domain, specifically when the domain was upgraded to new versions of RPAS (patches or releases). |
-listsubdomains |
Displays a list of all the local domains in a global domain environment and indicates which positions at the partition level are in each local domain. This argument is only valid when run on a global domain. |
-masterdomaininfo |
Lists the master domain path and partition dims for subdomains. |
-integrationStatus |
States if the domain is integrated with an RPAS Data Mart. If the domain is integrated, it also prints out the domain identifier for the domain and the path to the RDM repository. |
-all |
Displays the domain version, expected domain version, domain type, associated application, history, integration status, subdomains, and master domain info (where applicable). |
Displays the file size information for the domain. |
Displays the number of strings of all given lengths that occur in the domain. The output returns a list by string length, for example:
0 758
1 21
2 8
3 69
Displays how many occurrences of each unique string there are in the domain. The output returns a list of each unique string, for example:
785 '' 1 '#copied <> #pasted' 2 '%' 1 '%1 <= passwd <= %2' 2 '%1 Window'
Displays array btree density. |
Displays how many arrays in the domain are formatted for each schema. The output returns a list like the following:
Count of Array Schemas for Domain ’domain'
Array schema 10: 371
Unknown schema:
-version |
Displays the version of this utility. |
-subdomain dim,pos |
Indicates to which local domain the specified position belongs. The position can be at or below the partition level. |
Displays all array paths to dimRegistry. |
-showrelativepaths |
Indicates if paths are relative when listing subdomains. Only relevant in combination with -listsubdomains or -all. |
Removes the header information from the output, thereby returning only the requested information. |
The checkDomain utility is used to check the validity of an existing domain. Its primary purpose is to verify that a master domain matches its respective local domains and report all discrepancies to the administrator.
checkDomain -d pathToDomain -type expectedType {-q}
Table 12-2 provides descriptions of the arguments used by the checkDomain utility.
Table 12-2 Arguments Used by the checkDomain Utility
Indicates the path to the domain that needs to be validated. |
Indicates the expected type of domain: simple, master, or sub. |
Indicates quiet mode. Do not display progress messages. |
When checkDomain is run on a simple domain, the following two items are validated:
The domain directory exists
It is a simple domain
If checkDomain is run on a global domain, it verifies the following:
The global domain exists
The global domain is a master domain
The global domain checks all of the subdomains for:
The subdomain directory exists and is a subdomain type
If the master domain and the subdomain have a repos directory
The measures, rules, rule groups, templates, and functions are the same in the global and subdomain
If it is run on a subdomain, it checks all of the items listed above for the global domain, but the validation is only performed between the global domain and the specified subdomain.
Use the rpasversion utility to determine which version of the RPAS Server is running in a particular location.
Use listDb to list the basic information of all arrays contained in the databases provided.
listDb pathToDb* listDb -row -db pathToDb* listDb -row -pageUsage -db pathToDb* listDb -row -standardOptions -db pathToDb* listDb -standardOptions -db pathToDb* listDb -version
Table 12-4 provides descriptions of the arguments used by the listDb utility.
Use printArray to print the contents of an array.
printArray -array db.array -specs {-maxpos num} {-format "formatString"} printArray -array db.array {-cell "dim1:pos1,dim2:pos2,..." printArray -array db.array -slice "dim1:pos1,dim2:pos2,..."{-format "formatString"} {-cellsperrow num} {-noposnames} printArray -array db.array -allpopulatedcells {-format "formatString"}{-cellsperrow num} {-noposnames}
Table 12-5 provides descriptions of the arguments used by the printArray utility.
Table 12-5 Arguments Used by the printArray Utility
-array db.array |
Specifies the array to print. Specify the full path to the database containing the array. Required for all commands except -version. The db is a full or relative path to a database. Do not specify the .ary suffix. If no other commands are included, the array defaults to -allpopulatedcells with cells per row 1. The -allpopulatedcells command is still available, but now functions as a useful default action. The -noposnames, -cellsperrow, and -format parameters may still be specified when relying on the implicit -allpopulatedcells behavior. |
Prints the specifications of the array and positions along each dimension. |
Outputs only the popcount of the specified array. Useful to shell script writers in order to get the |
Prints a specific cell value from the array. Must not contain spaces. Must identify a single of 1-D slice. Specify using the format |
Outputs a specific cell value with no space padding. Useful for scripts when capturing cell values into shell variables. Must not contain spaces. Must identify a single of 1-D slice. Specify using the format |
Prints a one-dimensional slice from the array. Must not contain spaces. Must identify a single of 1-D slice. Specify using the format |
Print all populated cells including the NA value of the array. |
If fmtstr (formatString) determines how dates are interpreted and can include:
For multi-cell output commands ( |
Suppresses the output of position names, only cell values are shown. |
Use the printMeasure utility to print measure information. The printmeasure utility cannot be used to print the data of a shared measure. If printmeasure is called with a shared measure as an argument, it will exit with an error messages stating that the measure is shared.
printmeasure -d domainPath {-wb wbName} {-m measure} [COMMAND]
Table 12-6 provides descriptions of the arguments used by the printMeasure utility.
Table 12-6 Arguments Used by the printMeasure Utility
Specifies the domain that contains the measure to print. Requires the |
Specifies the measure to print. |
Specifies the workbook associated with the measure to print. If |
Returns a list of all registered measures in the domain. This argument does not require |
Returns a list of all measures registered at or above the partition dimension in a global domain. |
Returns the list of measure properties. Requires the |
Returns the base intersection of the measure. |
-slice CELLSPEC |
Prints a one-dimensional slice from the array. Must not contain spaces. Must identify a single of 1-D slice. Specify using the format "dim1:pos1,dim2:pos2,…" |
-cell CELLSPEC |
Prints a specific cell value from the array. Must not contain spaces. Must identify a single of 1-D slice. Specify using the format "dim1:pos1,dim2:pos2,…" |
-allpopulatedcells |
Print all populated cells including the navalue of the array. |
