This chapter discusses how to:
Set up implementation defaults.
Set up HRMS options on the PeopleTools Options page.
Administer country codes.
Set up regulatory regions.
Establish regulatory transaction types.
Setting Up Implementation DefaultsTo set up implementation defaults, use the Installation Table component (INSTALLATION_TBL).
This section provides an overview of implementation defaults and discusses how to:
Select PeopleSoft applications for your installation.
Select HRMS options.
Enter application and industry-specific installation information.
Enter country-specific installation information.
Select local country functionality.
Specify the starting number for system-assigned numbers.
Define parameters for using third-party applications.
Enter alternate character types.
Understanding Implementation Defaults
For each site where you implement PeopleSoft HRMS, you must complete the Installation Table to specify various defaults, processing rules, and counters for the system to use. You can have only one set of installation information for each site; this information is required.
Warning! You must complete the information on the Org Defaults by Permission Lst component (OPR_DEF_TBL_HR) for each primary permission list. Most of the defaults in PeopleSoft HRMS come from the Org Defaults by Permission Lst component and not the Installation Table pages. Other PeopleSoft HRMS applications have defaults that are based on the Installation Table settings. However, in PeopleSoft Enterprise Human Resources, all defaults are based on the settings that you make on the Org Defaults by Permission Lst component. There are some exceptions to this rule in PeopleSoft Human Resources, and they are noted in the default field level discussion.
See Setting Up Primary Permission List Preferences.
When you access the Installation Table pages for the first time, you’ll see that PeopleSoft has already entered information for a sample company that you can use as a guide. After you enter your installation information, log off to save your changes.
Pages Used to Set Up and Report on Implementation Defaults
Page Name |
Object Name |
Navigation |
Usage |
INSTALLATION_TBL1 |
Set Up HRMS, Install, Installation Table, Products |
Specify the PeopleSoft applications for your installation. |
INSTALL_GP_SEC |
Set Up HRMS, Install, Installation Table, Products Click the Installed GP Countries link on the Products page. |
Select the PeopleSoft Enterprise Global Payroll country extensions you are implementing. |
INSTALL_PIP_SEC |
Set Up HRMS, Install, Installation Table, Products Click the Installed Integration Packs link on the Products page. |
Select the payroll integration pack you are using, if applicable. |
INSTALLATION_TBL1B |
Set Up HRMS, Install, Installation Table, HRMS Options |
Specify how to drive your system: by person, by position, or both. Enter the PeopleSoft HRMS defaults that are related to your organizational policies. |
INSTALLATION_TBL1A |
Set Up HRMS, Install, Installation Table, Product Specific |
Enter product- and industry-specific installation information. |
INSTALLATION_TBL3 |
Set Up HRMS, Install, Installation Table, Country Specific |
Enter country-specific installation information. |
INSTALLATION_SEC |
Set Up HRMS, Install, Installation Table, Country Specific Click the Installed HR Countries link on the Installation Table - Country Specific page. |
Specify which local country functionality to activate for users in PeopleSoft Enterprise Human Resources. |
INSTALLATION_TBL2 |
Set Up HRMS, Install, Installation Table, Last ID Assigned |
Specify the number that the system uses to start assigning numbers. |
INSTALLATION_TBL4 |
Set Up HRMS, Install, Installation Table, Third Party/System |
Set the criteria for gathering statistics and activate the SQR security for PeopleSoft HRMS. Define parameters for using third-party applications such as Visio. |
ALT_CHAR_TBL |
Set Up HRMS, Install, Installation Table, Alternate Character |
Specify the language code and alternate character type. |
PRCSRUNCNTL |
Set Up HRMS, Install, Installation Table Report, Run Control |
Run the Installation Table report (PER702). This report lists default values for field defaults, such as company code, minimum/maximum standard hours, and Social Security number. |
Selecting PeopleSoft Applications for Your InstallationAccess the Products page.
Select the applications you are installing. To access that application’s functionality, you must select it on this page.
If you are implementing PeopleSoft Global Payroll, select the Installed GP Countries link to select the Global Payroll country extensions you are implementing.
If you are implementing an integration pack, select the Installed Integration Packs link to select the integration pack.
(USF) Setting Up PeopleSoft HRMS for Federal Functionality
To set up your database for U.S. federal government functionality, select Federal on the Installation Table - Products page and update the Org Defaults by Permission Lst component to point to the U.S. federal government industry and sector.
To set up your database for military functionality, select Militaryon the Installation Table - Products page.
Make your primary permission list preference changes on the Settings page of the Org Defaults by Permission Lst component. To set up a federal database, select an Industry of Government and an Industry Sector of US Federal.
Selecting HRMS OptionsAccess the HRMS Options page.
Company |
Select the default company code. The system uses this default in several tables in PeopleSoft Human Resources. For a single-company organization, enter the code for that company; for multicompany environments, determine which company is most appropriate. |
To use this functionality to control payroll input in PeopleSoft Global Payroll, review your payroll and make sure that the elements reference the appropriate PeopleSoft Human Resources items. The system does not use them automatically.
Min Standard Hours (minimum standard hours) and Max Standard Hours (maximum standard hours) |
Enter the minimum and maximum standard hours that workers are expected to work in the standard work period. The system enters this information as default values but you can override the values on either the Job Code component (JOB_CODE_TBL) or Position Data component (POSITION_DATA). |
Default Standard Hours |
Enter the number of hours in a standard work period at the company. This is a required field. When you define preferences for a primary permission list, the standard hours appear by default from the Installation Table. The value that you enter also becomes the default standard hours value for a job in the Job Code Table component and the default standard hours value in the Salary Plan Table component (SALARY_PLAN_TABLE). PeopleSoft Human Resources uses standard hours to compute a full-time equivalency (FTE) value to prorate holiday hours and pay for part-time and hourly workers. |
Work Period |
Select a standard work period (the time period in which workers must complete the standard hours). Values are stored on the Frequency table. The system uses the annualization factor of the standard work period in combination with the standard hours to calculate FTE. |
See Classifying Jobs.
To drive part or all of the system by position, change the setting in this group box.
If you use PeopleSoft Enterprise Pension Administration, don’t use position management for your retiree organization. If you use position management for your workers, select Partial to exclude retiree departments.
Note. Using position management substantially alters the way that the system processes your data, and requires you to maintain data differently.
Full |
The system expects that you track position data for all people in your organization and that you drive your human resource system by position, not by person. |
Partial |
The system uses whatever position data is available, but doesn’t require that you track your entire organization using position management. Select to use the business process on a trial basis or for selected departments. |
None |
You drive your system by person. You can still assign position numbers to people, but the system doesn’t use position data for job records, such as work phone or mail drop ID. This is helpful for tracking only certain positions, such as those above a particular management level. |
Default Comp Frequency (default compensation frequency) |
Select the value to use for reporting salaries. This field is required. The system also uses this value as the default compensation frequency in the Job Code Table. |
Use Rate Code Groups |
Select if your organization bundles rate codes to apply percentages when calculating compensation. |
Use Salary Points |
Select if your organization uses rate codes that have the rate code type points. |
Multi-Step Grade |
Select if your organization uses a multistep/grade salary plan. This causes the system to use the Salary Step Components page (SALARY_PLAN_T3GBL) to determine compensation rates. |
Multi-Currency |
Select if you use different types of currency to pay people. This option affects only PeopleSoft Enterprise Payroll for North America. PeopleSoft Global Payroll uses a separate multicurrency in the payroll system. Note. Select the Multi-Currency check box on the PeopleTools Options page (PSOPTIONS). |
Base Currency |
Select a currency code from the values in the Currency Code page (CURRENCY_CD_TABLE). The code you select is the default currency that the system uses to calculate compa-ratios (percent through range calculations) and all total amounts on pages and reports for PeopleSoft Human Resources and PeopleSoft Payroll for North America, regardless of the currency that is used for individual line items. For example, if the U.S. dollar is your base currency, but your global salespeople submit expense reports in French francs, the system calculates the expense total in U.S. dollars by internally converting all line item amounts to U.S. dollars and displaying the total in U.S. dollars. Note. All currency defaults in PeopleSoft Human Resources are based on the base currency that you indicate on the Installation Table page, not the Org Defaults by Permission Lst component. The Org Defaults by Permission Lst component doesn’t affect the currency defaults on the local country pages. |
See PeopleSoft Enterprise Components for PeopleSoft Enterprise HRMS and Campus Solutions 9.0 PeopleBook: “Currencies”
Rate Type |
Identify the default rate type on which your currency conversion is based. Do this only if you haven’t specified a default rate type for a primary permission list on the Org Defaults by Permission Lst component. The system checks the Org Defaults by Permission Lst component for a default rate type first; if none is specified, it looks at this value. |
See Also
PeopleSoft Enterprise Human Resources 9.0 PeopleBook: Managing Base Compensation and Budgeting
Setting Up and Working with Currencies
Entering Application- and Industry-Specific Installation InformationAccess the Product Specific page.
FMLA Administration (Family Medical Leave Act), COBRA Administration (Consolidated Omnibus Budget Reconciliation Act administration), Benefits Billing, , Retroactive Benefits / Deductions and FSA Claims Administration |
Select to activate these different types of benefits functionality. |
Start Date for BenAdmin (start date for Benefits Administration) |
Enter the start date in PeopleSoft date format: MM/DD/YYYY. |
Benefits Deductions Class Order
When the 415(c) limit is met, the deduction classes are limited in the following order: Employee Before-tax contribution , Employee After-tax contribution, Ptax Benefit (Employer Before tax Match), & then the Nontaxable Benefit (After Tax Employer Match). The user can change the deduction class order when the limit is met by selecting PTax Benefit then EE After Tax — Employer Before Tax Contribution is limited first then the Employee After Tax Contribution. The deduction class order will then be Employee Before-tax contribution, Ptax Benefit (Employer Before tax Match), Employee After-tax contribution & then the Nontaxable Benefit (After Tax Employer Match).
NA Payroll / Payroll Interface (North American Payroll and Payroll Interface)
Concurrent Calc/Confirm (concurrent calculation and confirmation) |
Select to enable the system to run a calculation and confirmation at the same time. It is possible for a person to be in two concurrent runs; this could cause a deadlock situation where the process ends abnormally. |
Automatic Employee Tax Data |
Select to enable the system to create employee federal, state, and provincial tax records automatically whenever the following criteria are met:
Use State Residence for Local |
Automatically selected when you select Automatic Employee Tax Data. Leave this field selected to assume that an employee is a resident of any local tax jurisdiction that happens to be located in the employee's state of residence. If this assumption is not true, clear this field to prevent resident local taxes from being erroneously deducted from an employee's paycheck. |
Multi-Company Organization |
Select if your organization comprises more than one company. Select if you use PeopleSoft Pension Administration, because you set up companies specifically to house your pension payees. |
Automatic Job Termination |
Select to automatically terminate any job that has an end date. The system does this by creating a termination row for the job. |
Automatic Job Suspension |
Select to activate substantive job suspension for workers working in temporary assignments where the substantive job requires suspension for the duration of the assignments. |
‘Temporary SSN’ Mask (temporary Social Security number mask) |
Enter a three-digit number to be a default Social Security number for all applicants or people whose Social Security numbers are unavailable. Assign a value that is greater than 800 so that the temporary number doesn’t conflict with valid Social Security numbers. |
EMPLID Field Length |
Enter the number of characters to be used for EmplIDs. |
Default Pay Basis |
For the Default Pay Basis, select the value to use for quoting and reporting salaries. This field is required if you selected Federal on the Products page. |
NFC Indicator |
Select this check box to expose National Finance Center (NFC) fields on impacted components and run the associated Peoplecode logic. |
AP Invoice Prefix (accounts payable invoice prefix)
AP Inv. Prefix (accounts payable invoice prefix) |
(Optional) Enter a prefix to be used for accounts payable invoices that are generated through HRMS. |
T&L/NA Payroll Paysheet Opt (Time and Labor and Payroll for North America paysheet options)
Change Final Check, Change Online Check, and Change Reversal Adjustments |
Select to enable payroll users to make paysheet changes to data that is retrieved from PeopleSoft Enterprise Time and Labor. PeopleSoft recommends not selecting these check boxes because changes that are made directly to the paysheets aren’t transmitted to PeopleSoft Time and Labor. |
Load in Preliminary Calc (load in preliminary calculation) |
The Pay Calculation process uses the value of the Load in Preliminary Calc field to determine whether to load new available time (additional time that was worked before the job change but not previously loaded on paysheets):
Note. If an employee had a Job data change that caused paysheets to be rebuilt, the Pay Calculation process attempts to reload all valid time and rejects time that is no longer valid as a result of the Job data change. This is true regardless of the setting of the Load in Preliminary Calc field. In this case, the process first rejects all previously loaded time, then it reloads the available time. If Load in Preliminary Calc is not selected, some new time might be loaded, but only for the employee being processed due to the Job data change. |
Commitment Accounting
Encumbrance Trigger |
Select to enable pre-encumbrance and encumbrance triggers to be processed from various online events. Each event cause the system write a record to the Encumbrance Trigger table (ENCUMB_TRIGGER), which is then used as input for the Nightly Encumbrances batch process (RUNCTL_ENC_NHT). |
General Ledger
GL Version |
Displays the version of PeopleSoft Enterprise General Ledger that is interfacing with PeopleSoft HRMS. Click the Update Version button if you change versions. The system will automatically update the GL Version. Note. Full chartfield functionality is only available when you use PeopleSoft General Ledger 8.4 or higher. |
Click to test the integration with PeopleSoft Enterprise Financials and display the latest version of Financials. |
Cache Validations |
Select to cache the results of your validations. This improves performance by enabling you to cached validations. |
Cache Retention Days |
Enter the number of days to store validation results. The system will delete anything in the cache older than this. |
See Also
Benefit Information Automation
Entering Country-Specific Installation InformationAccess the Country Specific page.
Country |
Select a country for the system to enter as a default value. |
Lang Cd (language code) |
The system displays the default base language for the database. |
Installed HR Countries |
Select this link to go to the Installed HR Countries page, where you can select which local country functionality is installed in the system. |
Last ROE # (last record of employment number), Last Dir Dep File Creation # (last direct deposit file creation number), Last FSA CarryForward Claim # (last flexible spending account carry-forward claim number), and Last CPS Transmission ID # (last CPS transmission ID number) |
Enter the last ROE, direct deposit file, flexible spending account carry-forward claim, and CPS transmission ID numbers that were used. The system increases each number by one when it assigns a new number. The system also updates the Installation Table every time it assigns a number. These values are used in PeopleSoft Payroll for North America when running a Canadian payroll. |
Census Metro Area (census metropolitan area) |
Enter the Census Metro Area (CMA) code that is prescribed by Statistics Canada for this location. The system uses the default CMA code that you enter only if no default CMA code is specified on the Org Defaults by Permission Lst component. CMA refers to the main labor market area of an urban core with a population of at least 100,000. This field is required for Canadian companies. |
Industrial Sector |
Used for Canadian employment equity purposes. The system uses the default value that you enter only if no default industrial sector is specified on the Org Defaults by Permission Lst component. This value is used as the default for the Canadian Industrial Sector field in the Department component; and it identifies the industrial sector with which people in a given department are associated. This field is required. |
Education & Government |
Select this check box for Australian public service organizations. |
Additional Appointment Enabled |
Select if you will be implementing Additional Appointment tracking (Kenmu). Selecting this check box activates functionality to create a dummy additional appointment job code when you create a new business unit. |
Selecting Local Country FunctionalityAccess the Installed HR Countries page.
The system displays a flag for each country that has special local functionality in PeopleSoft Human Resources:
Select a check box to activate local functionality for that country. Users who have security access can see and work with that country’s local functionality.
Clear a check box to hide that local functionality from your users.
If the check box for a country is selected on this page, but you don’t grant country access to the users' primary permission list on the Setup Global Security – Global Panels page (SCRTY_TBL_GBL), users will not see local country functionality.
See Setting Up Security for Local Functionality.
Specifying the Starting Number for System-Assigned NumbersAccess the Last ID Assigned page.
In PeopleSoft HRMS, there are several fields where you can either enter numbers manually or let the system assign them.
The following table lists auto-numbering fields.
Field |
Application |
Business Process |
Last Employee ID Assigned |
PeopleSoft Human Resources |
Administer Workforce Recruiting Workforce |
Last HS Non-Employee ID Assgn |
Monitor Health and Safety Administer Training |
Last TL Contractor ID Assigned |
PeopleSoft Time and Labor |
Administer Workforce |
Last COBRA Emplid Assigned |
PeopleSoft Benefits Administration PeopleSoft Human Resources: Base Benefits |
Administering COBRA |
Last Position # Used |
Manage Positions Plan Successions |
Last Grievance # Used |
Manage Labor Administration |
Last Car # Used |
Administer Company Cars |
Last Demand ID Assigned |
Budget Training |
Last Combination Code Assigned |
PeopleSoft Human Resources PeopleSoft Payroll for North America |
Commitment Accounting |
Last AP Invoice Number |
Last H/S Claim # Assigned |
Monitor Health and Safety |
Last Incident # Used |
Last Journal # Assigned |
Administer GL Interface |
Last Help Context # Used |
PeopleSoft HRMS |
Customizing Windows Online Help |
Last Retro Pay Request Seq # |
Manage Retroactive Pay |
Last Retro Ded Request Seq # |
Manage Retroactive Benefits/Deductions |
Last FSA Claim # Assigned |
PeopleSoft FSA Claims Administration |
Administer FSA |
Last Illness # Assigned |
Monitor Absence |
Last Illness # Report Assigned |
Monitor Absence |
Last Temp Assignment # Used |
Last Used Element Number |
Manage Profiles |
To let the system assign numbers for the fields on this page, enter the last number that you used in the field. The system increases that number by one when it assigns a new number. The system updates the Installation Table every time it assigns a number.
Note. To avoid maintaining two different sets of numbers, either always assign numbers manually or always let the system do it.
When you convert ID data to PeopleSoft Human Resources from another system, enter the highest number that was used in your previous system so that you don’t duplicate IDs. If the last ID you assigned in your previous system was 1000, enter 1000 in the Last Employee ID Assigned field. When you add a person in PeopleSoft Human Resources, the system assigns an ID of 1001 and updates the Last Employee ID Assigned field accordingly.
To always enter IDs manually, enter 999999999 (nine 9’s) in the Last Employee ID Assigned and Last Applicant ID Assigned fields.
If you use Social Security or insurance numbers as IDs, change the formatting for the Employee ID field using PeopleSoft Application Designer.
To make data entry faster and more accurate on several pages when you enter a number that the system has assigned, the system enters zeros before the number. For example, when you enter 4, you see 00000004, a total of 8 characters per number. This occurs in the following fields:
Job Opening
Requirements Search
Grievance
Incident
Claim
Position
Note. If you have already assigned numbers that aren’t zero-filled, change their numbering so that the system can accurately track
them when you convert the data to PeopleSoft Human Resources.
For more information about data conversion, ask your human resources project leader or see the PeopleSoft Application Designer
documentation.
See Also
Enterprise PeopleTools PeopleBook: PeopleSoft Application Designer
Defining Parameters for Using Third-Party ApplicationsAccess the Third Party/System page.
Performance Monitor Parameters
Start Time For Stats Gathering (start time for statistics gathering) and Stop Time For Stats Gathering (stop time for statistics gathering) |
Enter the date and time of the start and stop. |
Gather Statistics for Table |
Select to gather statistics locally. |
Gather Statistics Globally |
Select to gather statistics globally. |
Write Interval |
Enter the number of seconds for gathering the statistics. |
Organization Chart |
Enter the type of third-party program you use to create organizational charts with your human resources data. |
Max Number of Rows in Scrolls (maximum number of rows in scrolls) |
Enter the maximum number of rows in a scroll-controlled data box for third-party systems. |
Commit After Empl Processed (commit after employee processed) |
Enter the maximum number of people that a third-party system processes before committing. |
See Also
Enterprise PeopleTools PeopleBook: Data Administration Tools
Setting Up and Building Organization Charts
Entering Alternate Character TypesAccess the Alternate Character page.
Note. Because you are setting the alternate character code on the Installation Table, the setting affects your entire HRMS application configuration. Make sure that you account for all language codes for your installation.
If you don’t specify an alternate character type for a language code that a user is working with, and the user tries to enter characters in an Alternate Character field, a warning message appears.
If you specify an alternate character type for a language code, and a user enters any other character type in an Alternate Character field, a warning message appears.
Note. You can ignore the warning message and enter the data in another character set, but problems can occur when data is sorted in multiple alternate character sets.
Setting Up HRMS Options on the PeopleTools Options PageTo set up HRMS options on the PeopleTools Options page, use the PeopleTools Options component (PSOPTIONS).
This section discusses how to set up HRMS options on the PeopleTools Options page.
You use the PeopleTools Options page to set a variety of values that are related to:
Multi-company organizations.
Organizations that conduct business using more than one currency.
Multiple jobs functionality.
Access the PeopleTools Options page on the PeopleTools, Utilities, Administration menu.
See Enterprise PeopleTools PeopleBook: Data Administration Tools
Select the following check boxes, as applicable, to activate these kinds of functionality:
Select if your organization comprises more than one company or if you use PeopleSoft Pension Administration to set up companies specifically to house your pension payees. |
Multi-Currency |
Select to enter data in more than one currency. For example, if you have offices in the United States and Italy, you may want to calculate pay rates in both U.S. dollars and Italian lira. If you select Multi-Currency, the system displays a Currency Code field on pages where amount fields appear. Note. Multi-Currency doesn’t affect PeopleSoft Global Payroll, which has its own multiple currency functionality. |
Multiple Jobs Allowed |
PeopleSoft delivers PeopleTools with this option selected. Leave it selected to take full advantage of PeopleSoft HRMS. |
See Also
Enterprise PeopleTools PeopleBook: Security Administration
Administering Country CodesTo administer country codes, use the Country Table component (COUNTRY_TABLE), the Country Table – HR component (HR_COUNTRY_TABLE), and the State/Province component (STATE_DEFN).
This section provides an overview of country codes and enterprise integration points and discusses how to:
View and update country information.
Specify the address format for a country.
Specify the county, state, and city for a country.
Define additional information for HRMS reporting purposes.
Add the state, province, or equivalent entity for a country.
Understanding Country Codes
On many pages in PeopleSoft Human Resources, a country appears as part of the address for a person, a company, or an office. Countries are represented as codes, such as CAN for Canada, and they are listed in the Country Table component. In the Country field on any page, the system displays a default country code, which you can change. The Org Defaults by Permission Lst component and the Business Unit Options Defaults component (BUS_UNIT_OPT_HR) can affect this default code. You can define the information that users should capture for addresses in specific countries using the Address Format page (ADDR_FORMAT_TABLE) in the Country Table component.
You need codes for all the countries where your organization does business and where the people in your system live. The Country Description page (COUNTRY_DEFN) includes an extensive list of predefined countries and codes. The page is updated with each version of PeopleSoft Human Resources according to the countries that are recognized by the International Standards Organization (ISO).
If you need a new country code, notify your PeopleSoft account manager so that we can add it to the Country Table for the next version of PeopleSoft Human Resources.
Pages Used to Administer Country Codes
Page Name |
Object Name |
Navigation |
Usage |
COUNTRY_DEFN |
Set Up HRMS, Install, Country Table, Country Description |
View or update country information. |
ADDR_FORMAT_TABLE |
Set Up HRMS, Install, Country Table, Address Format |
Specify the address format for the country that is selected from the Country Table. |
EO_ADDR_VALIDAT |
Set Up HRMS, Install, Country Table, Valid Address |
Specify the county, state, and city for the country that is selected from the Country Table. |
Country Table - HR |
HR_COUNTRY_DEFN |
Set Up HRMS, Install, Product and Country Specific, Country Table - HR |
Specify additional information about a country for HRMS reporting purposes. |
STATE_DEFN |
Set Up HRMS, Install, State/Province, State or Province Table |
Add a state, province or equivalent entity for the country that is selected from the Country Table. |
PRCSRUNCNTL |
Set Up HRMS, Install, Country Table Report, Run Control |
Run the Country Table report (PER708) that prints a list all country character codes. |
Viewing or Updating Country InformationAccess the Country Description page.
2-Char Country Code (Two-character country code) |
Enter the code that the U.S. government assigned to the country, if applicable. |
EU Member State (European Union member state) |
Select if this is an EU member state. This field is for your reference only and doesn’t impact system processing or reporting. |
Specifying the Address Format for a CountryAccess the Address Format page.
Address Edit Page |
Select an address page from the list of available options. The system will display the list of fields on that page in the Address Fields group box. |
Enable Address Search |
Select to enable the address search. |
Enable Address Validation |
Select to enable the system to validate address entries for state or province and city as shown on the Valid Address page. |
Address Fields
Field Name |
The Field Name column displays the address fields available in the PeopleSoft HRMS. |
Edit Label Override |
Enter a different label to override the displayed Field Name, if required for this country. |
Include in Display? |
Select to have the system display this field whenever an address in this country needs to be entered in the system. |
Include in Print? |
Select to have the system print this field whenever an address in this country will be printed. |
Line Number |
Enter the line on the page on which this field should appear. |
Position Number |
Indicate this field's position in the selected line. |
Use Description? |
Select to have the system display a full description for this field. |
Pre Separator and Post Separator |
Enter separator characters for the address elements if applicable (for example and em dash). |
Specifying the County, State, and City for a CountryAccess the Valid Address page.
Valid Addresses
The Valid Address page stores state/province codes with corresponding cities, as entered on the State or Province Table page. When you select Enable Address Validation on the Address Format page, the system checks address entries against the values stored on the Valid Address page to verify that the city and state or province match.
Note. (JPN) Japanese postal data is stored in both the Postal Code Table and the Valid Address table (EO_ADDR_VALIDAT). To keep the Valid Address table in sync with the Postal Code Table, you must enter new postal data in the Postal Code Table page. The system will not update the Postal Code Table with values you enter on the Valid Address page.
See Also
(ITA) Setting Up Italian City Codes
Maintaining the Postal Code Table
Defining Additional Information for HRMS Reporting Purposes
Access the Country Table - HR page.
(AUS) Australia
Australian Public Service |
Enter the Australian Public Service four digit country code here. |
(BEL) Belgium
NIS Country Number (National Institute for Statistics country number) |
Enter the NIS Country Number for reporting hires and terminations to the Social Insurance. |
(FRA) France
INSEE Country Number (National Institute for Statistical and Economic Studies country number) |
INSEE is an official statistics and economics organization in France. This organization issues a number that is used by the tax authorities, Social Security, the Chamber of Commerce, and others to identify an enterprise and its entities. |
(NLD) Netherlands
Nationality |
Enter the four-digit nationality code for the country. Nationality codes are defined by the Netherlands coding standard (NEN) and are used in wage declarations for the Netherlands. The system uses the Country code specified for an employee on the Citizenship/Passport page to determine which nationality code applies to the employee. |
(USA) USA
Country Code for 1042 |
(USA) Enter the country code used when reporting wage and tax data to federal and state government agencies in the MMREF format. (E&G) Enter the country code for nonresident alien processing |
Adding the State, Province, or Equivalent Entity for a CountryAccess the State or Province Table page.
PeopleSoft delivers the State or Province Table with all states, provinces, and equivalent geographical entities (such as Dutch communities and French departments) for all supported countries. The codes are based on standard postal codes. PeopleSoft updates this table with each version.
You need these state or province codes for all countries where your organization does business. You use this information in many address fields in the system.
Postal Abbreviation |
The state or province code is automatically displayed. |
Numeric Code |
Enter the numeric code, if applicable. The U.S. federal government assigns a numeric code to each state for reporting purposes. You don’t need to enter numeric codes for new Canadian provinces. |
Setting Up Regulatory RegionsTo set up regulatory regions, use the Regulatory Region component (REG_REGION).
This section provides an overview of enterprise integration points and discusses how to define regulatory regions.
Page Used to Set Up Regulatory Regions
Page Name |
Object Name |
Navigation |
Usage |
REG_REGION |
Set Up HRMS, Install, Regulatory Region, Regulatory Region |
Set up a regulatory region. |
Defining Regulatory RegionsAccess the Regulatory Region page.
Country |
Select a country from the list. When you create a regulatory region, you must specify the country to which the region belongs. This enables country-specific edits even when a state-level or provincial-level region is used in a system transaction. If the country you want to add isn’t in the list of values, add that country to the system using the Country Table. |
Security Access |
Select a security access level from the list. Because many companies have users working with only one, limited set of regulatory regions, this feature enables you to hide the other regulatory regions from the user. The values are stored on the Translate table. The Regulatory Region prompt edit views use these values to limit the user’s Regulatory Region choices to the regions to which the user has access. Values are as follows:
Note. If you choose not to maintain the country-level data security, then select Available to All or Not Available to Anyone to provide universal access to regulatory regions. To simplify maintenance, availability is established only once for each regulatory region and is used for all transactions. |
Use this group box to specify the SetIDs that make up this regulatory region. Since Regulatory Region is used to drive set processing in some applications, such as Health and Safety, Regulatory Region is a set control value. The default record group SetIDs establish an initial set processing relationship for this new regulatory region.
SetID |
When you add a regulatory region, the SetID field is available for entry, and the Clone From Existing Regulatory Region field is unavailable for entry. The system places a default setID in the SetID field that bears the same name as the Regulatory Region Code that you just defined. If you haven’t defined a SetID that matches this code, select another applicable SetID for your regulatory region from the list of valid values. The SetIDs in the list were set up using the TableSetID table. You can select only from those SetIDs. Note. Before you can specify SetIDs, you must define SetIDs, record groups, set control values, and TableSet record group controls, using the components on the PeopleTools, Utilities, System Administration menu. |
Clone from Existing Regulatory Region |
You can clone the SetIDs attached to this new regulatory region from an existing regulatory region. Use this option if the new regulatory region that you’re defining requires the same default record group SetIDs as those that you’ve already created for another region. Enter the regulatory region that you want to clone. |
See Also
Setting Up and Administering HRMS Security
Establishing Regulatory Transaction TypesTo establish regulatory transaction types, use the Regional Transactions component (REG_TRX_REGION).
This section provides an overview of regulatory transactions and discusses how to add regulatory regions to a transaction.
Understanding Regulatory Transactions
Two sets of regulatory transactions are already defined in the system as shown in the following table:
Regulatory Transaction |
Countries or Regions Included |
Reason |
STANDARD |
All countries that are supported in the system. |
Most applications apply regulatory and legislative edits at the country level. |
HANDS (Health and Safety) |
All countries that are included in the system, plus the Canadian provinces. |
Most applications apply regulatory and legislative edits at the country level, but Canada has specific provincial laws governing their Health and Safety reporting. |
Use the two pages in the Regional Transactions component (REG_TRX_REGION) to assign new regulatory regions to these transaction types (if you have added countries or regulatory regions to the system) and to establish new regulatory transactions.
Pages Used to Update or Add Regulatory Transactions
Page Name |
Object Name |
Navigation |
Usage |
REG_TRX |
Set Up HRMS, Install, Regional Transactions, Transactions |
Update the regulatory transaction description or add a new regulatory transaction. |
REG_TRX_REGION |
Set Up HRMS, Install, Regional Transactions, Regions in Transaction |
Define the regulatory regions that make up a regulatory transaction type. |
Adding Regulatory Regions to a TransactionAccess the Regions in Transaction page.
Regulatory Region |
Select the regulatory regions that belong to this transaction. |
Installing Person Objects
To install person objects, use the Person Object Installation component (INSTALL_PERSON).
This section discusses how to install person objects.
Page Used to Install Person Objects
Page Name |
Object Name |
Navigation |
Usage |
Install Person |
INSTALL_PERSON |
Set Up HRMS, Install, Person Object Installation, Install Person |
Select installation settings for the Add a Person component (PERSONAL_DATA). |
Selecting Personal Data Installation Settings
Access the Install Person page.
Installation settings for PERSONAL_DATA functions
Show Checklists |
Select to show the Checklists Code field on the Organizational Relationships page (PERSON_DATA4), enabling users to select a checklist for the person they are adding and create a record in the Person Checklist component (PERSON_CHECKLIST). |
Perform Automatic Search/Match |
Select to perform an automatic search and match when you add a person to the PERSONAL_DATA component. The system will search the database to determine that you are not entering a duplicate record. |
Default Checklists
Select the default checklists that the system will display in the Checklist Code field on the Organizational Relationship page when you add to add one of the following relationships for the new person:
Employee.
In the Employee Checklist field, select the default checklist for commercial employees.
In the French Public Sector Emp field, select the default checklist for French public sector employees.
Contingent worker.
In the Contingent Worker Checklist field, select the default checklist for contingent workers.
Person of Interest
For each POI type listed in the Person of Interest Type Checklist grid for which you want a default checklist, select the checklist.
The system will create a record in the Person Checklist component with this checklist if you select the Go to Person Checklist link on the Organizational Relationship page when you first create the person.
Set up checklists on the Checklist component (CHECKLIST_TABLE).
See Creating Checklists.
