This chapter provides an overview of vendor tables and discusses how to enter vendor information.
Understanding Vendor Tables
This section discusses vendors and the integration between HRMS and Enterprise Payables.
VendorsA vendor is any agency or organization that the company sends money to on behalf of a worker or that the company uses to withhold money from a person's paycheck. Vendors can be:
Benefit providers
Garnishment payees
Tax collectors
The system stores information about the vendor in the Vendor table. It holds the information necessary to make payments to a vendor and the policy information for a benefit provider.
Integration with Enterprise PayablesEnterprise Payables, Enterprise Payroll for North America and Enterprise Human Resources, Manage Base Benefits use Integration Broker to populate each other's Vendor tables.
Note. If you are using PeopleSoft Enterprise Payables to pay your vendors, we recommend that you enter and update vendors in the Vendor table through PeopleSoft Payables and export the Vendor table to PeopleSoft Human Resource Management System (HRMS).
Warning! If you update vendors through the HRMS tables, the contact information is exported to the Payable system. However, any changes to existing vendor bank information that are made through HRMS will not be exported to the Payables system.
Before using the integration to maintain the Vendor table, configure the Integration Broker nodes and activate the appropriate queues, handlers, and routings for these service operations:
Service Operation |
Description |
VENDOR_FULLSYNC |
Payables publishes all contents of the Vendor table to the HRMS Vendor table. |
VENDOR_SYNC |
Payables publishes updates in the Vendor table to the HRMS Vendor table. |
To research the technical details of any integration point used by PeopleSoft applications, refer to the Interactive Services Repository on Customer Connection.
See Also
Interactive Services Repository in the Implementation Guide section of Customer Connection.
Working with Integration Points in Enterprise HRMS
Enterprise PeopleTools PeopleBook: Integration Broker
PeopleSoft Enterprise Components for PeopleSoft Enterprise HRMS and Campus Solutions 9.0 PeopleBook
Maintaining Vendor Information
Entering Vendor InformationTo enter vendor information, use the Vendor Control (VENDOR_CONTROL), Vendor Information (VNDR_ID), Provider/Vendor Table (PROVIDER_TABLE), Payee Table (GARNISH_PAYEE_TBL), and Payee Table USF (GVT_GARNISH_PAYEE) components.
This section provides an overview of vendor setup pages and discusses how to:
Identify vendor prefixes.
Enter basic vendor information.
Enter vendor address information.
Display alternate names for use on payments.
Identify vendor locations.
Enter bank account information.
Enter payment processing information.
Enter vendor contact information.
Enter benefit policy information.
(USF) Enter garnishment payee contact information.
(USF) Enter garnishment payee distribution information.
Understanding Vendor Pages
To enter vendor information, you will complete the following pages:
Vendor Control
Vendor Information
Addresses
Locations
Contacts
Policy Information
This is used only if you want PeopleSoft Payables to pay the vendor. It provides a mechanism for identifying the different types of vendors.
This page creates the vendor code and identifies the name and type of vendor you are entering.
This is a strictly address information and should not be confused with location. You can enter multiple addresses for the different sites a vendor might have.
A vendor location is not a physical address. It is a default set of rules, or attributes, which define how you conduct business with a particular vendor. A vendor's location comprises information such as payment terms, remittance information, bank account information, and so on. Although a location is not an address, it will reference addresses.
Your vendor may need only one location. If the vendor uses the same set of rules across its business, you can simply enter one location for your vendor, and you're ready to go. If, however, your vendor uses different sets of rules for different portions of its business (different branches, sites, or offices, for example) you can set up the vendor with multiple locations, each with its own unique set of business rules.
This page is used to enter information about the people whom you contact on a regular basis. You can enter an unlimited number of vendor contacts and identify their roles so that you can easily determine whom you should contact if you have questions, or discern why a contact might want to talk to you, before you return their call.
Policy information is necessary for benefit providers. You will link this vendor and policy information using the Benefit Plan table in Base Benefits.
Pages Used to Set Up Vendors
Page Name |
Object Name |
Navigation |
Usage |
VNDR_CNTRL |
Set Up HRMS, Product Related, Payroll for North America, AP-Vendors, Vendor Control |
Identify the prefix assigned to the vendor in PeopleSoft Payables. |
VNDR_ID1 |
Enter basic vendor information. |
VNDR_ADDRESS |
Enter a vendor’s address information. |
VNDR_ADDR_ALTN |
Click Alternate Names on the Addresses page.
Enter any alternate name for use on payments. |
VNDR_ADDR_PHN |
Click Telephone on the Addresses page.
Enter a vendor’s phone information for addresses. You can enter more than one phone number per address. |
VNDR_ADDR_EMAILID |
Click Email ID on the Addresses page.
Enter a vendor’s email addresses. |
VNDR_LOC |
Enter address and remittance information. |
VNDR_BANK_ACCOUNT |
Click Bank Accounts on the Locations page.
Enter banking information for the vendor. |
VNDR_BANK_ACCT2 |
Click Bank Accounts on the Locations page and Bank Address on the Bank Accounts page.
Enter the bank’s address information. The bank’s Country defaults from the Bank Accounts page. The form of the address fields varies, depending on the country. |
VNDR_BANK_ACCT3 |
Click Bank Accounts on the Locations page and Phone Details on the Bank Accounts page.
Enter phone information for the bank. |
VNDR_LOC_COMMENTS |
Click Comments on the Locations page.
Enter notes or comments about locations. |
VNDR_PAY |
Click Payment Options on the Locations page.
Enter payment processing rules for the vendor location. |
VNDR_CNTCT |
Enter a vendor’s contact person. Enter more than one phone number if necessary. |
VNDR_CNTCT_PHN |
Click Phone Information on the Contacts page.
Enter a contact’s telephone information. |
VNDR_POLICY |
Enter information about policies and whom to contact about them. |
GVT_GARN_PAYEE |
Set Up HRMS, Product Related, Payroll for North America, Garnishments, Payee Table USF, Garnishment Payee |
Enter garnishment payee contact information for U.S. federal government. |
GVT_GARN_DIST_SEC |
Set Up HRMS, Product Related, Payroll for North America, Garnishments, Payee Table USF, Garnishment Payee Click the Distribution Information button on the Garnishment Payee Table page. |
Enter garnishment payee distribution information for U.S. federal government. |
Identifying Vendor PrefixesAccess the Vendor Control page.
Use Auto-Numbering |
PeopleSoft Payables has the option of using an autonumbering feature to assign IDs to new vendors. |
HRMS Vendor ID Prefix |
If you selected the auto-numbering check box, enter a prefix that is used identify HRMS vendors. |
Entering Basic Vendor InformationAccess the Vendor Information page.
Name 1 |
Enter the payee name as it should appear on the check. |
HRMS Class (HRMS classification) |
This field identifies the HRMS classification used to create views so you see the appropriate vendors on the appropriate tables. It is also used to identify tax and non-tax deductions when the system extracts deductions to create AP vouchers. Available values are:
For benefit providers, select P for General Provider. |
Status |
For HRMS vendors, select Approved. The other values are used by Enterprise Payables. |
Persistence |
For HRMS vendors, select Regular. The other values are used by Enterprise Payables. |
Entering Vendor Address InformationAccess the Addresses page.
Address Type |
Enter the one or more addresses for the vendor. If you are using PeopleSoft Payables at least one address should be the remittance address. This is the address that is used when creating payment vouchers. Premium Payment and Remittance are the only valid address types for deduction recipients. If any other address type is displayed for this vendor, contact your Accounts Payable department. Premium Payment t generally applies to benefit deductions and Remittance applies to all other types of deductions including taxes. |
Displaying Alternate Names for Use on PaymentsAccess the Alternate Names page.
Alternate Name 1 and Alternate Name 2 |
When the system generates payments for the location using this address, Enterprise Payables needs to use a name different from the one entered on the Vendor Information page, enter the name here. |
Identifying Vendor LocationsAccess the Provider/Vendor Table - Locations page.
Location |
Enter an identifier for the location information you are entering. If more than one location is set up for the vendor, you can use the previous page and next page links on the Vendor Location bar to display information for the location in which you’re interested. |
Default |
Select this check box if you want this location to automatically print on the vouchers for this vendor. Only one location can be selected as the default. |
Remit Vendor |
This is the information about the vendor to whom payments will be sent. You need to select the codes that identify the name of the vendor receiving the payments, vendor location, and address where the payment is sent. |
Bank Accounts |
Click this link to display the Bank Accounts page. Work with the Payroll department to set up this information. |
Comments |
Click this link to display the Comments page. |
Payment Options |
Click this link to display the Payment Options page. Work with the Payroll department to set up this information. |
Entering Bank Account InformationAccess the Bank Accounts page.
Default |
The Default check box is selected if this is the default bank account for the location. The default bank account is copied to each payment schedule for this vendor. |
Bank ID Qual |
The country-specific numeric value by which the bank/counterparty is identified. This value controls how the bank/counterparty pages edit and display bank information. |
Branch ID |
The branch ID for the bank, if appropriate. |
Bank ID |
The Bank ID for the bank. |
Acct Type |
The account type for the bank, Bond, Checking Account, and Life Insurance, for example. |
Account # |
The vendor’s bank account number. |
Check Digit |
The check digit used by the bank. |
DFI Qualifier |
If you make automatic clearing house (ACH), wire, or EFT payments to this vendor location, this field should display the appropriate DFI Qualifier: The value determines the format for the DFI ID field.
The DFI Qualifier determines the format of the bank’s DFI ID. |
DFI ID |
The bank’s DFI ID. The format is determined by the value displayed in the DFI Qualifier field. |
Bank Address |
Select Bank Address for the Bank Address page. |
Phone Details |
Select Phone Details for the Phone Details page. |
Entering Payment Processing InformationAccess the Payment Options page.
Payment Control
Hold Payments |
If this check box is selected, PeopleSoft Payables automatically places payments for this vendor on hold. |
Separate Payment |
If this check box is selected, PeopleSoft Payables creates a separate payment for each voucher, even if the system processes multiple vouchers for the vendor in the same pay cycle. |
Bank
Bank ID |
The code for the bank from which you want to make payments for this vendor. |
Bank Account |
The account from which payments will be made to this vendor. |
Payment Handling
Flag |
This field determines the payment handling instructions.
Code |
If you select Specify at this Level in the Flag field, this field displays the payment handling instructions your accounts payable department follows when issuing payments for this vendor:
Payment Method
Flag |
This field determines the payment method:
Code |
If you select Specify at this Level in the Flag field, this field displays the payment method for this vendor:
Entering Vendor Contact InformationAccess the Contacts page.
Sequence No (sequence number) |
This number is automatically assigned to this contact. |
Type |
Select the type of contact. |
Address |
Select one of the addresses that you entered on the Addresses page. |
URL |
Enter the contact’s website address. |
Phone Information |
Click this link to display the Provider/Vendor Table - Contacts: Phone Information page. |
Entering Benefit Policy InformationAccess the Provider/Vendor Table - Policy Information page.
General Policy URL ID |
Select the vendor’s website address that provides general policy information. |
Authorized Providers URL ID |
Select the vendor’s website address that contains a list of authorized participating providers |
Sequence |
Select a contact from the list of contacts that were entered on the Provider/Vendor Table - Contacts page. After you select the contact, the Contact Name automatically appears. |
(USF) Entering Garnishment Payee Contact InformationAccess the Garnishment Payee page.
Distribution Information |
Click this button to access the Deduction Distribution Information page. |
(USF) Entering Garnishment Payee Distribution InformationAccess the Deduction Distribution Information page.
Enter the payment information.
Payment Method |
For EFT distributions, select EFT as the payment method and specify the remittance state and FIPS code in addition to the account information. |
See Also
Entering Garnishment Deduction Distribution Information
(USA) Specifying EFT Information for Child Support Garnishments
