This chapter discusses how to:
Identify integrations for your implementation.
Activate service operations and queues.
Work with HRMS local integrations.
Work with other HRMS integrations.
Identifying Integrations for Your ImplementationPeopleSoft uses PeopleSoft Integration Broker to integrate HRMS applications with:
Other PeopleSoft Enterprise HRMS applications inside of the database (local integrations).
PeopleSoft applications outside of Enterprise HRMS.
Third-party applications.
Use the Interactive Services Repository (ISR) on Customer Connection to identify the integrations that you need for your implementation. Documentation provided with the ISR application on Customer Connection provides instructions for using search pages to query the repository using a variety of criteria:
By integration point name.
By product.
Integrations between products.
By business process.
By integration technology.
Using an advanced search page.
The advanced search page enables you to combine the individual search criteria into a single search.
Click an integration point in the search results to see its details.
See Also
Customer Connection, Implementation Guide, Implementation Documentation and Software, Interactive Services Repository
The ”Interactive Services Repository” PDF instructions on Customer Connection, Implementation Guide, Implementation Documentation and Software, Interactive Services Repository.
Activating Service Operations and QueuesIntegration messages are connected to service operations, which are delivered inactive. You must activate the service operations that your organization uses.
In the PeopleTools, Integration Broker, Integration Setup, Service Operations component:
Verify or select the Active status for the service operation on the General page.
Verify or select the correct routing status on the General page.
Activate the appropriate handlers and associated application classes on the Handlers page.
Activate the correct routing on the Routings page.
In the PeopleTools, Integration Broker, Integration Setup, Queues component, set the status of the corresponding service operation queue to Run.
Note. You must also configure Integration Broker.
See Also
Enterprise PeopleTools PeopleBook: Integration Broker
PeopleSoft Enterprise Components for PeopleSoft HRMS and Campus Solutions 9.0 PeopleBook
Working with HRMS Local IntegrationsThe system uses a local to local integration when the database that does the publish also has a handler and associated application class on the service operation that triggers other processing within that database.
Setup Requirements
When using local integrations, you must configure only the local node, but the application server must be running both the publish and subscribe servers. The local gateway and node must be properly configured. For local to local integrations, you must activate the asynchronous routing within the local node (local to local).
This table lists the local to local service operations in alphabetical order:
Service Operation |
Service Operation |
Service Operation |
ACCOUNT_CHARTFIELD_FULLSYNC |
EP_REVW_RATING |
PSXP_CLEANATTR |
ACTUAL_TIME_ADD |
EP_SUB_COMP |
PSXP_RATTR |
ACTUAL_TIME_BATCH_ADD |
EP_SUB_DEV |
PTAF_MASS_APPROVALS |
AWARD_GRANT_ISSUE |
EP_SUB_PROF |
PUNCHED_TIME_ADD |
BUDGET_POSITION_FULLSYNC |
EP_SUB_WRT |
QAS_CRASH_MSG |
BUS_UNIT_FS_FULLSYNC |
ESTIMATED_TIME_BATCH_ADD |
ROLE_MAINT |
BUS_UNIT_FS_SYNC |
FUND_LOAD |
TIME_DEVICE_EMPL_ATT_FULLSYNC |
BUS_UNIT_GL_FULLSYNC |
GP_POST_GL |
TIME_DEVICE_EMPL_ATT_SYNC |
BUS_UNIT_GL_SYNC |
GRANT_AWARD_UPDATE |
TIME_DEVICE_PER_HRS_FULLSYNC |
COUNTRY_FULLSYNC |
HCR_EM_EVENT |
TIME_DEVICE_PROFILES_FULLSYNC |
COUNTRY_SYNC |
HCR_EM_EVENT_QUEUE_1 |
TIME_DEVICE_RESTRICT_FULLSYNC |
DEPBEN_SYNC |
HCR_EM_EVENT_QUEUE_2 |
TIME_DEVICE_RPTG_CODE_FULLSYNC |
DEPT_FULLSYNC |
HCR_EM_EVENT_QUEUE_3 |
TIME_DEVICE_RPT_ELMNT_FULLSYNC |
DEPT_FULLSYNC_EFF |
HIRE_REQUEST |
TIME_DEVICE_SCHEDULE_FULLSYNC |
DEPT_SYNC |
HR_ACCT_CD_LOAD |
TIME_DEVICE_SUPERVSOR_FULLSYNC |
DEPT_SYNC_EFF |
HR_CHARTFLD_COMBO_SYNC |
TIME_DEVICE_TASK_VALS_FULLSYNC |
DETAIL_CALENDAR_FULLSYNC |
JOURNAL_GEN_APPL_ID_FULLSYNC |
TIME_DEVICE_TEMPLATES_FULLSYNC |
ELAPSED_TIME_ADD |
LOCATION_SYNC |
TIME_REPORTING_CODE_FULLSYNC |
EP_CHK_SUG |
PAYMENT_ERECRUIT_ACKNOWLEDGE |
TREE_CHANGE |
EP_CHK_WRD |
PAYMENT_ERECRUIT_ISSUED |
UOM_FULLSYNC |
EP_COMPETENCY |
PAYMENT_ERECRUIT_REQUEST |
UOM_SYNC |
EP_COMP_DEV |
PERSON_ERN_DELETE |
USER_PROFILE |
EP_COMP_PROF |
POST_HIRE_REQUEST |
VAR_COMP_PAYMENT_ACKNOWLEDGE |
EP_DEV_TIP |
PRODUCT_CHARTFIELD_FULLSYNC |
WORKFORCE_FULLSYNC |
EP_JPM_CAT_ITEMS |
PRODUCT_CHARTFIELD_SYNC |
WORKFORCE_SYNC |
EP_JPM_CAT_ITEM_RD |
PROJECT_ACTIVITY_FULLSYNC |
WP_PSHARING_MSG |
EP_JPM_CAT_I_RLAT |
PROJECT_FULLSYNC |
EP_RATING_MDL |
PSXP_ARCHATTR |
See Enterprise PeopleTools PeopleBook: Integration Broker
Working with Other HRMS IntegrationsIntegrations that support particular business processes are documented throughout PeopleSoft HRMS PeopleBooks.
This table provides references to integration information in HRMS PeopleBooks:
PeopleBook |
Reference |
PeopleSoft Enterprise Global Payroll 9.0 PeopleBook |
PeopleSoft Enterprise Human Resources 9.0 PeopleBook: Manage Professional Compliance |
PeopleSoft Enterprise Human Resources 9.0 PeopleBook: Manage Variable Compensation |
PeopleSoft Enterprise Payroll for North America 9.0 PeopleBook |
See Integrating with PeopleSoft HRMS and Enterprise Expenses. |
PeopleSoft Enterprise Stock Administration 9.0 PeopleBook |
PeopleSoft Enterprise Talent Acquisition Manager 9.0 PeopleBook |
PeopleSoft Enterprise Time and Labor 9.0 PeopleBook |
See Integrating with PeopleSoft Financials and Enterprise Performance Management. |
See TCD Interface. |
Note. To research the technical details of any integration point used by PeopleSoft applications, refer to the Interactive Services Repository in the Implementation Guide section of Customer Connection.
