Registering Interfaces
This chapter provides an overview of the HCM interface registry and discusses how to:
Note. The HCM Service Framework User Guide red paper, which is posted on Oracle's PeopleSoft Customer Connection, provides additional technical information for developers, architects, and development managers who design, implement, maintain, or develop applications that leverage the HCM Service framework.
See Also
Click to jump to parent topicUnderstanding the HCM Interface Registry
The HCM interface registry holds all the interface specifications for available services in the Service Oriented Architecture (SOA). It stores contracts from service providers and provides those contracts to interested service consumers. The service provider registers the interface, the consumer locates the interface in the registry and uses the information to bind and execute the contract between the consumer and the provider.
The service consumer finds an interface in the registry and the registry provides the information necessary to bind and execute the service
The service consumer is an application, service, or some other type of software module that requires a service. It is the entity that initiates the location of the service in the registry, binding to the service over a transport, and executing the service function. The service consumer executes the service by sending it a request formatted according to the contract.
The service provider is the service, the network-addressable entity that accepts and executes the requests from consumers. It can be a mainframe system, a component, or some other type of software system that executes the service request. The service provider publishes its contract in the registry for access by service consumers.
To set up and use an interface registry:
  1. Set up the interface contract and register the interface using the Registration Wizard (Setup HRMS, System Administration, HCM Registry, Registry Wizard).
  2. Implement the interface in the providing application.
  3. Set up the consuming application to invoke registered interfaces.
Setting Up Interface Contracts
An interface contract specifies the way a consumer of a service will interact with the provider of the service, including the format of the request and response from the service. The HCM registry is populated with the existing interface contracts within HCM. To add new interfaces to the registry, you must first define the contract between the services.
To define an agreement between services, follow these steps:
  1. Determine the interface details (such as signature, exceptions, and warnings).
  2. Register the interface under the provider object identifier.
  3. Set the interface status to Active.
Note. Register interfaces using the HCM registry's Registration Wizard.
Interfaces fall into one of the following categories:
Click to jump to parent topicManaging the HCM Interface Registry
To mange the HCM interface registry entries, use the Service Registry component (HMCR_IFC_REGISTRY).
Click to jump to top of pageClick to jump to parent topicPages Used to Manage the HCM Interface Registry
Page Name
Object Name
Navigation
Usage
HMCR_IFC_REGISTRY
Set Up HRMS, System Administration, HCM Registry, Service Registry, HCM Interface Registry
Review the HCM registry and modify existing entries.
<Registry Folder Label>
HMCR_IFC_FLDR_ACT
Click on an interface folder.
Generate and audit the WSDL for a selected interface folder.
Audit - <Registry Folder Label>
HMCR_IFC_AUD_RSLT
Click on an interface service.
Review the results of a registry folder audit.
Interface Registry - Details
HMCR_WSDL_VIEWER
HMCR_IVW_VIEWER
HMCR_TYPE_VIEWER
Click on an interface for a service, sqlView, type, or exception.
Review registry and interface details about a selected interface.
<Registry Entry Name>
HMCR_WSDL_RAW_SEC
Click on an interface for a service, and then click on the Show WSDL button; or, click on an interface for a type or exception, and then click on the Show XSD button.
View WSDL code for a service registry entry, or view XSD code for a type or exception registry entry.
Click to jump to top of pageClick to jump to parent topicUsing the HCM Interface Registry
Access the HCM Interface Registry page.
The registry lists all the content owners and their interfaces in a tree format. Each tree leaf represents a registered interface. Registered interfaces are grouped by interface folders. Click a registered interface to review interface information on the Details page.
Owner Identifier
Select an owner identifier.
The registry displays all interfaces (public and private) defined for the selected content owner in addition to all public interfaces defined by owners other than the selected owner.
Refresh Cache
Click this button to manually refresh the cache where services, types, exceptions, and SQL views are stored whenever you make a change to the registry. You must refresh the cache when a definition is modified, added, or deleted. You must also refresh the cache when an external cache has to be imported.
Generate Registry Doc
Click this button to generate RegistryDoc for the selected HCM interface registry. The system generates RegistryDoc in HTML and provides the View RegistryDOC link for you to access the data. The RegistryDoc enables you to view or introspect the registry without having to open the registry, thus offering a quicker view into the registry.
Note. RegistryDoc generation relies on configuration of PeopleTools Process Scheduler and report nodes. You should set the directory that acts as the report repository in a shared mode.
View RegistryDoc
Click this link to view RegistryDoc that you have generated. The system opens a new browser window, which displays the registry API content in HTML format.
Searching the Registry
Use the Search capability to look up a registry when:
Search Descriptions
Select this check box to search descriptions of registry entries for an exact word that you specify in the Search Filter field.
Select this check box and the Search Descriptions check box to search descriptions of registry entries for the word pattern that you specify in the Search Filter field.
Wildcard Search
Select this check box to search registry entries for the word pattern that you specify in the Search Filter field.
Search Filter
To search registry entries for an exact match of a service, sqlView, type, or exception, enter a value in this field without selecting any check boxes. The system lists the registry entry.
To search registry entries for a word pattern, enter the word pattern in this field and select the Wildcard Search check box. The system lists registry entries that match the pattern that you entered.
To search descriptions of registry entries for an exact word, enter the word in this field and select the Search Descriptions check box. The system lists registry entries with descriptions that contain the exact word.
To search descriptions of registry entries for a word pattern, enter the word pattern in this field and select both the Search descriptions and Wildcard Search check boxes. The system lists registry entries with descriptions that match the pattern that you entered.
Search
Click this button to retrieve the registry entries that match your search criteria.
Link
Click the link to access the details of the registry.
Click to jump to top of pageClick to jump to parent topicViewing WSDL Code for Registry Folders
Access the <Registry Folder Label> page.
Use the View WSDL group box to review the WSDL that the system generated for the selected registry folder. Click the Run Audit button to run an audit on the registry folder. The system displays the Audit - <Registry Folder Label> page for you to review the results of the registry folder audit.
Click to jump to top of pageClick to jump to parent topicReviewing Registry Folder Audit Results
Access the Audit - <Registry Folder Label> page.
Click to jump to top of pageClick to jump to parent topicReviewing Registry and Interface Details
Access the Interface Registry - Details page.
Note. The Interface Registry - Details page is slightly different for each type of interface (services, sqlViews, types, and exceptions).
Registry Details
UUID
The UUID is the interface's unique identifier for a service within the registry. The system generates this identifier.
Locate By
The system automatically displays this value where applicable.
Version
Each registry entry has a version type. You can have multiple versions of an entry when you require multiple version of an interface.
Status
An interface can have one of the following statuses within the registry:
  • Requested
    The interface has been requested by a party but has not been implemented.
  • In Work
    The interface is currently being defined.
  • Active
    The interface is ready for use.
  • Deprecated
    The interface has been replaced by a more current version, but is still supported.
  • Retired
    The selected version of the interface has been retired.
Note. The status of an interface is specific to the entry version.
Scope
This field indicates who can reference this version of the interface:
  • If the interface is Public, it can be used by any application.
  • If the interface is Private, it can only be used within the provider module.
Generate Consumer Code
Click to generate the consumer stub code for this registry entry. Use this code to implement the service.
See Implementing Registered Interfaces.
Generate Provider Code
Click to generate the provider stub code for this registry entry. Use this code to implement the service.
Show WSDL
Click this button to generate Web Services Definition Language (WSDL) code for the service registry entry. WSDL code provides you with all the details about the service that is needed for consuming a service. The system displays the <Registry Entry Name> page where you can view the WSDL code.
Note. Definitions for sqlViews, types, and exceptions do not have WSDL viewing capability.
Show XSD
Click this button to generate XSD code for a type or exception registry entry. XSD code contains the definition of a particular type, which is information that is necessary for consuming complex types. The system displays the <Registry Entry Name> page where you can view the XSD code.
Note. Definitions for services and sqlViews do not have XSD viewing capability.
Run Audit
Click this button to run an audit of the selected registry folder. Audits ensure that the registry is clean. They also enable you to monitor discrepancies between implementation and contracts. The system displays the Audit - <Registry Folder Label> page, where you can review the results of the audit.
Interface Details
Interfaces are defined using an XSD schema. The schema for each interface type is stored in the registry. The system generates the schema during registration.
Note. The schema defines the details of sqlView interfaces, not the database view that implements the view interface. The database view must match the properties defined in the schema.
Service interface types have operations called DoServices. A DoService has one or more input, output, and outfault element and each element is defined by either one or more simple or complex type.
Exception Details
Review a service interface's exception details and the associated messages.
Implementation Details
In the Implementation Details group box, review the fully qualified application class path that implements class for this type or exception. The class path includes a branch indicating the version of this type. The version attribute of the registry entry must match the version in the class path of the type class.
Note. For sqlView interfaces, the Implementation Details box displays the database view implementing the interface view.
Note. All exceptions must extend the class baseException, which extends the PeopleTools built-in exception class.
Click to jump to top of pageClick to jump to parent topicViewing WSDL and XSD Code for Registry Entries
Access the <Registry Entry Name> page.
Click to jump to top of pageClick to jump to parent topicViewing RegistryDoc
To view RegistryDoc, click the Generate Registry Doc button on the HCM Interface Registry page. The system generates the RegistryDoc and displays the View RegistryDoc link.
Click the View RegistryDoc link. The system opens a new browser window, which displays the registry API content in HTML format.
The page contains three frames. The upper left frame lists the root packages within the RegistryDoc. Click a link for a root package in the upper left frame to view for a list of all of the services, sqlViews, types, and exceptions that are associated with the selected root package. The system displays the details of the selected root package within the lower left frame. The right frame displays the services, sqlViews, types, and exceptions for all root packages.
Click a link in the lower left frame or the right frame to view service, sqlView, type, or exception details.
From a service details page, click on the View WSDL link to view WSDL code for the selected service.
If a service or type refers to another complex type or exception, click on the type link on the details page to view type or exception details.
Click to jump to parent topicRegistering New Interfaces
To register new interfaces, use the Registration Wizard component (HMCR_WZ_REGSRV).
Click to jump to top of pageClick to jump to parent topicPages Used to Register New Interfaces Through the Registration Wizard
Page Name
Object Name
Navigation
Usage
Registry Information
HMCR_WZ_STEP1
Set Up HRMS, System Administration, HCM Registry, Registration Wizard, Registry Information
Enter information about a new interface.
Interface Specification
HMCR_WZ_STEP2
Set Up HRMS, System Administration, HCM Registry, Registration Wizard, Interface Specification
Enter details about the new interface.
Implementation
HMCR_WZ_STEP3
Set Up HRMS, System Administration, HCM Registry, Registration Wizard, Implementation
Complete the registration of the new interface by implementing the interface.
Click to jump to top of pageClick to jump to parent topicEntering Interface Information in the Registry Wizard
Access the Registry Information page.
Type
Select the interface type.
Note. The pages in this component and the information you enter can vary depending on the type of interface you select here.
Name
Enter a meaningful name for the interface using the following guidelines:
  • One word (no spaces).
  • Mixed case.
  • In one of the following formats, depending on the interface type:
    in the format, <Noun>Exception, <Noun>Service, or <Noun>sqlView, depending on the type of interface you are registering.
    • For Type interfaces: <Noun>Type.
    • For Service interfaces: <Verb><Noun>.
    • For Exception interfaces: <Noun>Exception.
    • For Interface Views: <Noun><Noun>.
Note. Users see the name you enter here on the registry tree so make sure that the name is clear and meaningful.
Version
Indicate the interface version using the format n.n.
You can have multiple active versions of an interface.
Status
Select the status of this version of the interface:
  • Requested
  • In Work
  • Active
  • Deprecated
  • Retired
Object owner identifier
Select the interface provider.
Scope
Indicate if the interface is Public (available to everyone) or Private (available only to the provider application).
Select parent folder
Click this link to access the registry folder structure and select the folder within which the new interface will reside. Group interfaces by feature.
Click to jump to top of pageClick to jump to parent topicEntering Interface Specifications
Access the Interface Specification page.
Note. The system displays a different version of this page depending on what type of interface you're registering. See the Registering Services section for information on how to use this page to register service interfaces.
Initialize from Implementation
If you are basing the Interface View definition on an interface that has already been implemented, click Initialize from Implementation and select the view. The system populates the elements with the fields from the fields in the view's record.
Note. The system only displays this link when you register Interface Views.
Seq Nbr (sequence number)
Indicate the order in which the element should occur.
Element Name
Enter the element name. An element is a property of the interface. Element names must be one word, mixed case, and self-describing.
Note. If you are implementing an Interface View, you must add an element to correspond with each field in the view's record.
Note. Service interface elements are descriptive items that identify the parameter in a given position. While the position of the elements must correspond to a parameter, it does not have to be a PeopleSoft field name.
Type Category
Select the element category. Categories indicate whether the element's data type is simple or complex. A simple datatype is a system-delivered data format. Complex datatypes reference other interface types already in the registry.
Note. Always select Complex for Exception elements.
Note. The system selects Simple for Interface Views and this field is unavailable for entry.
Simple Type
If the element is simple, select the element's system-delivered data format type:
  • xsd:string
  • xsd:date
  • xsd:number
  • xsd:boolean
Complex Type
If the type is complex, select the registered element to which it refers.
Note. If the interface is an exception, you must select ExceptionType from the Service Framework folder.
Minimum Occurrences
Indicate the minimum number of times this element can occur. Select 0 if the occurrence is optional and 1 if the element must occur at least once.
Note. You must select 1 for Exception elements.
Maximum Occurrences
Indicate the maximum number of times the element can occur.
When you register a service, enter the follow information in the four group boxes:
Click to jump to top of pageClick to jump to parent topicImplementing the Interface
Access the Implementation page.
Note. The system displays a different version of this page depending on what type of interface you're registering. See the Registering Interface Views section for information on how to use this page to register interface views.
Deployment and Deployment Node
The system displays this field only when you register a Service interface.
Indicate if the service is Local (resides in the same database as the consumer) or Remote (resides outside the consumer's database).
If the service is remote, select the deployment node.
Package Root
Select the provider's root package. The root suffix depends on the interface type you are registering:
  • For Type interfaces: <ownerID>_TYPES.
  • For Exception interfaces: <ownerID>_EXCEPTIONS.
  • For Service interfaces: <ownerID>_SERVICES.
Class Path
Select the class path to the appropriate version of your type class.
Implementation AppClass
Once you have implemented the class, return to the registry to select the interface's application class. Do not select a value when you initially register the interface; wait until you have implemented the interface.
Note. If you are implementing a Service interface, populate this field only if the service is local.
Generate Class Code
Click to generate the PeopleCode for the implementation AppClass. You can copy and paste the code into your application class object when you implement the interface.
Note. The system does not display this button when you register Service interfaces.
Register
Click to register the interface definition. When the system successfully registers the definition it will display the interface's UUID.
Interface View
After you have implemented a sqlView for this interface, return to this page and select the view that corresponds to this Interface View.
Related Language Interface View
The system displays the related language view defined in for the implementation in Application Designer, if one exists.
Click to jump to parent topicImplementing Registered Interfaces
After you have registered the interface, implement it in the providing application. The providing application must implement the interface accurately so that the consumer application does not encounter any unexpected behavior.
Click to jump to top of pageClick to jump to parent topicImplementing Types
To implement a registered type interface:
Note. Implement registered types as PeopleCode application classes.
  1. In Application Designer, create an application package for each functional module using the naming convention <NAMESPACE_PREFIX>_TYPES.
    Use the first level sub-package to group implementation classes by function and the second level to group classes by versions.
  2. Create the application class that is implementing the interface type.
    When you create the application class, you must ensure that it:
  3. Copy the stub code the system created when you clicked the Generate Class Code button on the Registry Wizard - Implementation page for this interface and paste it into the application class implementing the interface type.
    The generated type stub code includes the following mandatory methods:
    method toxmlNode(&parentNode As XmlNode); method fromXmlNode(&parentNode As XmlNode); method toXmlNodeString(&nodeName As string) Returns string; method TruncateType();
    The system uses the XML mandatory methods to marshal and unmarshal the type to or from an xml representation, which is required in order to use this type in a remote service invocation. The truncateType mandatory method resents the value of all type elements.
  4. Access the registry entry for the type interface in the Registry Wizard and add the application class to the type's implementation details.
Click to jump to top of pageClick to jump to parent topicImplementing Services
Consumer programs cannot directly instantiate service implementation classes. Due to late binding and remote procedure call support, the framework delays the resolution of the implementation class name until run-time so the only information available to service consumers during design is the interface name.
At run-time, the service manager resolves the interface name into the implementation class name using the registry lookup functionality. Depending on the implementation details defined in the registry, the service manager will return to the consumer either an instance of a local implementation class or a proxy class for the remote implementation.
Because of these considerations, the providing application needs to supply the following two application classes to fully implement a service:
Note. Implement registered services as PeopleCode application classes.
To implement a registered service interface:
  1. In Application Designer, create an application package for each functional module using the naming convention <NAMESPACE_PREFIX>_SERVICES.
    Use the first level sub-package to group implementation classes by function and the second level to group classes by versions. Use the third (application class) level to define an interface and an implementation for the service.
  2. Create two application classes to implement the service, an interface and an implementation class.
  3. Select the registry entry for this service and click the Generate provider Code button. The system displays a page with three group boxes containing code:
  4. Confirm that the interface and implementation classes contain the necessary information.
    The two applications serve different functions. The interface class is an abstract definition and details what methods and properties the implementation class will have to have to comply with registered specifications, but it does not contain the implementation details. The implementation class actually implements the interface, providing the executable code for the abstract method definitions.
    The interface application class must:
  5. Confirm that the implementation of the service:
  6. Access the registry entry for the service interface and add the implementation application class to the type's implementation details.
Note. You can use services to organize multiple other services to execute an business task. This is called aggregating services. The aggregating service is the service responsible for managing the business transaction, housekeeping, and performing the save professing so these processes are run only once, improving overall performance. When a service is running another service in aggregation mode, the calling service (the aggregating service) sets the RunAggregated flag on the called service, causing the called service to skip the housekeeping and save processing.
Click to jump to top of pageClick to jump to parent topicImplementing Exceptions
PeopleSoft delivers a baseException class providing the default exception handling, which is on the PeopleTools exception class. The baseException class constructor takes the following parameters:
The base Exception class constructor executes the following logic:
Note. Implement registered exceptions as PeopleCode application classes.
  1. In Application Designer, create an application package for each functional module using the naming convention <NAMESPACE_PREFIX>_EXCEPTIONS.
  2. Copy the stub code the system created when you clicked the Generate Class Code button on the Registry Wizard - Implementation page for this interface and paste it into the application class implementing the exception.
  3. Confirm that the exception implementation contains the following:
    Note. The exception's registry entry defines the exception name, the fault message structure, and the exception semantics (description).
  4. Confirm that the implementation of the exception class:
Click to jump to top of pageClick to jump to parent topicImplementing SQLViews
To implement a registered sqlView interface:
Note. Implement registered sqlView interfaces as PeopleSoft record definitions with a type of view.
  1. Create fields on the record definition to correspond to each field in the registered sqlView interface.
  2. Run SQL Create to create the view in the database.
  3. Open the sqlView registry entry and add the implementation record name to the registry entry.
    When you are creating a new interface view, you must use the Registry Wizard component. When you are updating an existing view, you must use access the registry and click the Update button. The system then displays the Registry Wizard component.
    See Registering New Interfaces.
Click to jump to parent topicConsuming Registered Interfaces
This section provides an overview of registered interface consumption and discusses how to:
Click to jump to top of pageClick to jump to parent topicUnderstanding Registered Interface Consumption
If there is an interface in the registry that your application needs to use, you must create code in PeopleCode events in the consuming application to invoke the interface.
Note. You can click the Generate Consumer Code button on the Registry Details page for the registered service to generate all the code the consuming application needs. Cut and paste the code into the consuming application's PeopleCode Event (for example, SavePostChange PeopleCode). Confirm that the generated code meets the criteria set out in these steps and make any necessary modifications.
Note. You can only place the code for manipulative services such as Set, Add, or Delete in the SavePostChange PeopleCode of a single field in a component. You cannot spread out manipulative service calls over several PeopleCode events. You must also not place manipulative service calls in FieldChange PeopleCode.
Click to jump to top of pageClick to jump to parent topicInvoking Service Interfaces
Consuming applications invoke service interfaces in four steps:
  1. Import, declare, and create framework classes, service classes, and type classes.
  2. Bind to the service implementation using the Service Manager's LocateService method.
    At runtime, the Service Manager determines the appropriate implemented interface application class and returns an instance of it to the consuming application for invocation as follows:
    1. The import statement in the consumer code indicates which registered interface is required.
    2. The registered interface contains information about which implemented interface class is required.
    3. The Service Manager's LocateService method returns an instance of the implementation class.
      Note. The LocateService method requires the service name and the service version in order to bind to the appropriate service.
    The consumer code only needs to know which registered interface it is using. The provider application specifies which implemented class should be returned to the consumer. This enables the provider to make changes to the implemented interface without impacting the consumer.
  3. If you are invoking a type interface, the consumer application needs to set the properties of the type class in the input parameters prior to passing it to the DoService call.
    The type interface registry entry describes the properties of the type class. The consumer can map properties individually from the consuming application to the type class properties.
  4. Invoke the DoService method of the service implementation class, passing the parameters as defined in the service signature.
    The service signature defines the zero or more input and output parameters that need to be passed to the service. Parameters can be simple types (such as string, number, date, or boolean) or complex types defined and registered as types in the interface registry:
  5. Catch and manage exceptions.
    The consumer code must invoke all services within a try-catch block. All code executed in between the try and the catch statement is in a protected area so that any exceptions thrown during service execution will immediately return control to the catch statement in the consumer code. The consuming application can then react to the exception.
    The consumer code can catch specific exceptions or the baseException, which is the parent class to all registered exceptions.
    Note. The consuming code should always catch for baseException to catch exceptions not specific to the service.
  6. Analyze the service execution log for relevant information.
    During service execution, the registry framework collects all warnings and messages issued by the provider and exposes them to the consumer as a service execution log. The consumer can query the execution log and take action based on the warnings and messages, if necessary.
    Each service has a property called ExecutionLog. The property has an array of LogType called Log. The LogType has the following attributes:
    The service's Log class has a generic method ShowLog() to display the content of the execution log.
Note. All consumer PeopleCode runs within the scope of a consumer component session. Any services that the system invokes during the component runtime will also run within this transaction scope. If the service execution encounters fatal errors, the system will roll back the entire component transaction unless the errors are specifically caught as exceptions. For example, if the a component in the consumer application uses two services invoked by the SavePostChange PeopleCode and one executes successfully while the other throws a fatal error, the system will not save any data to the component from either service.
Click to jump to top of pageClick to jump to parent topicSetting Up Stale Data Checks in Service Calls
If the service call is updating the component in the consumer application with an action of Add, you do not need to set up a check for stale data and you can invoke the service in Component.SavePostChange PeopleCode..
However, if the service is to update prior selected data, you need to set up a stale data check to ensure that the underlying data has not been modified during user interaction on the consumer side. To do this, create a Get service in the Component.PostBuild PeopleCode and a Set service in the Component.SavePostChange PeopleCode.
If the registry detects a discrepancy in the data, it will cause an error, which can be caught using baseException.
Click to jump to top of pageClick to jump to parent topicPooling Component Interfaces
Several services may use the same instance of a component interface in their implementations. To improve performance, you can pool component interfaces. Component interfaces must be scoped to one local PeopleCode event, but within that event the code can send several calls to services using the same open component interface.
The system then passes the component interface pool to the Service Manager's LocateService method. If a requestor is only issuing one service call in a Peoplecode Event, the system passes NULL as a component interface pool.
Click to jump to top of pageClick to jump to parent topicConsuming Collection-Sized Services
You can set up services to operate on items or on collections (row sets). If the consuming application is working with a collection of rows, you must set up the consuming application to pass the entire collection to the service. The service removes any items that are not passed into the service in the collection. If consumer passes an empty collection, it will effectively remove all the data rows in the provider implementation.
Use a collection-sized Get service to populate the collection type class, manipulate it, and pass it back to the Set service.
Click to jump to top of pageClick to jump to parent topicBinding Complex Types To and From the Portal Pages
All services work with simple or complex types as parameters. Simple types are available as PeopleCode data types. The provider application implements complex types as application classes. It is not possible to view application class properties directly on a page so it is necessary for the consumer application to create pages based on Rowset.Row.Record.Field objects and map the type class properties to the fields.
In the consumer code, set up a call to the helper method PopulateToRowset to bring all data from the type class instance to the user interface of the consumer component. Set up a call to the helper method PopulateFromRowset to bring all values from the rowset used in the user interface of the type class.
Note. Not all type classes provide helper methods and not all helper methods will work in all consumer components. In these cases, you will need to write your own logic to bind the type class values to the consumer user interface.
Click to jump to top of pageClick to jump to parent topicConsuming SQLViews
Consuming applications can use registered sqlViews directly without binding. Use registered sqlViews for the following:
Click to jump to parent topicMaintaining the Registry Folder Structure
To administer the HCM interface registry, use the Administer Service Registry component (HMCR_CONTENT_ADMIN).
This section discusses how to maintain the registry folder structure.
Click to jump to top of pageClick to jump to parent topicPage Used to Maintain the Registry Folder Structure
Page Name
Object Name
Navigation
Usage
Content Administration
HMCR_CONTENT_ADMIN
Set Up HRMS, System Administration, HCM Registry, Administer Service Registry, Content Administration
Add or delete folders from the registry.
Click to jump to top of pageClick to jump to parent topicMaintaining the Registry Folder Structure
Access the Content Administration page.
Create Folders
To create a new folder, select Create Folder in the Operation field and enter the folder's registry details.
Folder Label
Enter the folder label that will appear in the registry.
Owner ID
Select the folder content's owner ID from the list of options.
Final Level
Indicate if the folder is a final folder. A final folder can not have any child folders other than the folders for the four interface types. If you make this folder a final folder, the system will create the four interface folders.
If you leave this check box clear, the folder is a feature folder and you can add child folders to it.
Create Tree
After you have entered the folder details, click the Create Tree button. When you click the button the system generates a new registry tree. Navigate through the tree and select the node under which the new folder should go.
You can only place a new folder under folders that have the same owner ID and that are not final level folders.
Delete Folders
To delete a folder, select Delete Folder in the Operation field. Expand the registry tree, locate the folder you want to delete, and click on it. You cannot delete a folder that contains registered interfaces within one if it's child folders.
Click to jump to parent topicTesting Services
To test newly created services, use the Service Tester component (HMCR_SRV_TESTER).
This section discusses how to test services.
Click to jump to top of pageClick to jump to parent topicPage Used to Test Services
Page Name
Object Name
Navigation
Usage
Service Tester
HMCR_SRV_TESTER
Set Up HRMS, System Administration, HCM Registry, Service Tester, Service Tester
Test newly created services in this generic component.
Click to jump to top of pageClick to jump to parent topicTesting Services
Access the Service Tester page.
Use this page to test newly created services through a generic component. For example, if you create a new service using the Registration Wizard component and the corresponding implementation code, you can use this page to test the service and ensure that service you are committing works as designed. The system returns the results of the service test in a new window as XML.
Add, Correction, or Update/Display
Select the mode that the service will run in. You can use these options to test the service running in the various modes.
Use Tree Input and Use XML Input
Select to populate inputs using an XML format (SOAP 1.2) or using the tree structure. When you click the Use XML Input button, the system converts the tree inputs to the corresponding SOAP document. This is useful for testing remote services, for populating the inputs of a larger service, and for copying an existing service to a new service test (similar to “save as” functionality).
Use Input Parameters as Output
Select this check box for services which have no input parameters but do update the input parameters that are passed in. This is valid only for local services because remote services cannot update inputs by reference. It is not recommended for local services but can be used where local services where this situation exists.
Run Service
Click this button to invoke the service request after you have populated the inputs. Upon completion of the service call, the system displays the outputs of the service in a new window as XML.
Click to jump to parent topicViewing and Registering Transformation Maps
To view transformation maps, use the Transformation Registry component (HMTF_TRF_REGISTRY). To register transformation maps, use the Register Transformation Map component (HMTF_WZ_TRF).
This section discusses now to:
Click to jump to top of pageClick to jump to parent topicPages used to View and Register Transformation Maps
Page Name
Object Name
Navigation
Usage
HCM Transformation Maps
HMTF_TRF_REGISTRY
Set Up HRMS, System Administration, HCM Registry, Transformation Registry, HCM Transformation Maps
View HCM transformation maps.
Transformation Map
HMTF_WZ_STEP1
Set Up HRMS, System Administration, HCM Registry, Transformation Registry, Register Transformation Maps, Transformation Map
Create transformation maps for messages from one message version to another.
Click to jump to top of pageClick to jump to parent topicViewing Transformation Maps
Access the HCM Transformation Maps page.
Use this page to view details of transformation maps, which instruct the system to convert incoming messages (From) into (To) a specific format. Primarily this is done because, between release, the record definitions may have undergone a change.
Click to jump to top of pageClick to jump to parent topicRegistering Transformation Maps
Access the Transformation Map page.
When you need to exchange information between two different release of a PeopleSoft Enterprise product you must perform transformations. With each release record definitions sometimes undergo changes. Transformations enable you to scale these problems by transforming messages from one release to another. Use this page to create transformation maps for messages from one release to another and from one version to another.
Message Name
Select the message that needs to be transformed from one version to another.
Message Version
Select the version of the message that needs to be transformed for one version to another.
Application Release
Select which PeopleSoft Enterprise application release that the message belongs to. For example, specify whether the message is from the HRMS 8.3 system or the HRMS 8,8 system. The Default value is that the system use the current release of the product.
Transaction Type
Select the type of transaction of the message, either Inbound Asynchronous, Inbound Synchronous, Outbound Asynchronous, or Outbound Asynchronous.
Object Owner Identifier
Select the owner of the message object.
UUID
The system displays a unique identifier for the transformation. The system generates this identifier.
Transformation Definition
View the definition of the transformation in XML format.
Register
Click this button to register the transformation.
Click to jump to parent topicMapping HCM Services to Integration Broker
This section provides an overview of HCM service mapping to Integration Broker and discusses how to:
Click to jump to top of pageClick to jump to parent topicUnderstanding HCM Service Mapping to Integration Broker
You can invoke HCM services from remote (non-PeopleSoft) systems. The SOA framework contains built-in functionality to process an incoming requests (services) and return the required response. This built in functionality gives you the ability to:
PeopleTools Integration Broker serves as the transport mechanism for services. By mapping your HCM services to Integration Broker, you ensure that your HCM Interface Registry conforms to industry standards.
Click to jump to top of pageClick to jump to parent topicMapping HCM Services to Integration Broker
Mapping an HCM Interface Registry Folder to an Integration Broker Service
Initiate the mapping of HCM services to Integration Broker through the HCM Interface Registry. The system permits mapping at only third level folders, which are the lowest sub-categorization of HCM services for products.
To map the HCM Interface Registry metadata for a particular folder to an Integration Broker service:
  1. Click the folder name link on the HCM Interface Registry page for a third level folder.
    The system displays the WSDL for that registry folder.
  2. Click the Add to service repository button to add to the service repository.
    Provided that you have set up Integration Broker, the system displays details of the service.
    Note. The Delete from service repository button is available only when you have mapped the registry folder to the Integration Broker service repository, at which time the Add to service repository button becomes unavailable. This ensures that you can only perform the correct action.
The system automatically generates an Integration Broker service name for the folder. This service name is the UUID for the folder, which is unique string within the HCM Interface Registry and thus guarantees that each service has a unique name. Optionally, you can rename the Integration Broker service to give it a more meaningful name through the Service Administration component (PeopleTools, Integration Broker, Service Utilities, Service Administration). If you rename the service, the system still guarantees a unique name because the Service Alias field contains a copy of the UUID service name. This ensures that the delete process has a means of correlating the service with the HCM Interface Registry.
Note. Do not change the Service Alias field under any circumstances because it is critical to service delete processing.
Mapping an HCM Service to an Integration Broker Service Operation
Each HCM service that is in a registry folder on the HCM Interface Registry page is mapped to an Integration Broker service operation and can be found in the service that you have generated for the folder on the Services page (PeopleTools, Integration Broker, Integration Setup, Services). The system uses the name of the HCM service as the name for the service operation, unless that service operation already exists. If the service operation does already exist, an algorithm works within the length constraints of the Service Operation Name field (30 characters). The algorithm replaces the endmost characters with digits until it generates a unique name. The system retrieves the version for the service operation from the HCM Interface Registry.
Mapping Interface Details
The system maps each input and output interface to an integration Broker non-rowset based message, complete with generated schema. The system also assigns the version from the HCM Interface Registry. The base name for the messages is the HCM service name plus the suffix _IM or _OM to designate input or output interfaces, respectively (for example, ADDPOITYPE_IM) .
The system maps outfault interfaces to Integration Broker non-rowset based part messages. This is due to the limitation of Integration Broker having only one fault message per service operation. Therefore, the system creates all outfaults that are associated with a mapped HCM service within an Integration Broker container message. The system indicates outfault messages by using the suffix _FM (for example, ADDPOITYPE_FM).
Viewing Service Operation Security
The system assigns each service operation that you generate the standard HCSPSERVICE permission list. Access the permission list details for the web service on the Web Service Access page (PeopleTools, Integration Broker, Service Operations, General, click the Service Operation Security link).
Viewing Service Operation Handlers
The system assigns a handler to each service operation that you generate. The assigned handler references a generic handler class that is processing the incoming request, and generates the required response. The generic handler is HMCR_FRAMEWORK:IB_Framework:Handlers:IB_SyncRequestHandler. Access handlers for service operations on the Handlers page of the Service Operations component (PeopleTools, Integration Broker, Integration Setup, Service Operations).
Viewing Service Operation Routings
Within the HCM Registry there is no indication of consumers for a given service, so the system does not generate routings during the mapping process. It is up to the development teams to create the necessary routings.
Click to jump to top of pageClick to jump to parent topicDeleting Mapped Services
Use the HCM Interface Registry to delete HCM services that you have mapped to Integration Broker. The system makes available the Delete from service repository button in the HCM Interface Registry only for folders that you have already added to the Integration Broker metadata.
The delete process removes the following objects from the Integration Broker metadata:
Click to jump to top of pageClick to jump to parent topicUsing Integration Broker to Provide Web Services
One main reason for mapping HCM services to Integration Broker is to use Integration Broker's capability of providing web services. You can provide a web service only for service operations that you define as having any-to-local routing. You create these service operations, along with their handlers and routings, in the Service Operations component.
To set up any-to-local routings for service operations:
  1. Access the Service Operations component (PeopleTools, Integration Broker, Integration Setup, Service Operations).
  2. Select the Generate Any-to-Local check box in the Routing Actions Upon Save area of the General page.
  3. Save the component.
    The system updates the Any-to-Local value of the Routing Status area to Exists.
    The system also generates the routing and displays it on the Routings page of the component.
You can publish as a web service any service that has at least one service operation defined as any-to-local.
To publish a qualifying service as a web service:
  1. Access the Provide Web Service component (PeopleTools, Integration Broker, Web Services, Provide Web Service) to launch the Provide Web Service Wizard.
    The system displays the Select Services page.
  2. Search for the service that you wish to publish as a web service.
  3. Select that service in the returned search results, and then click the Next button.
    The system displays the Select Service Operations page.
  4. Select the service operation for the service that you want to publish as a web service, and then click the Next button.
    The system displays the View WSDL page.
  5. Click the View WSDL link for a service to view the WSDL that the system generated for the service.
  6. Return to the View WSDL page and click the Next button.
    The system displays the Specify Publishing Options page.
  7. Define where to publish the selected services.
    Select the Publish to UDDI check box or the WSDL Repository check box to publish the services to the corresponding location.
    The system displays the Provide Web Service - Results page.
  8. View the WSDL generation log to confirm the results of the wizard.
