This chapter provides an overview of mass organization changes and discusses how to perform mass organizational changes.
Understanding Mass Organization Change
Governmental changes and mandates might require making the same organizational change to a large group of your PeopleSoft Human Resources records. For example, an agency restructuring may require that you transfer of a group of employees from the Office of the Director, Budget Division to the Office of the Director, Account Standards Division. Instead of performing this transfer manually, record by record, you can make the changes all at once using the Mass Organization Change functionality.
The Mass Organizational Change processes enable you to make changes based on department and position changes. Using the Mass Organization Changes features, you can:
Transfer employees into existing departments or positions.
Create new departments or positions, changing the organizational structure and transfer employees into the new departments or positions.
Merge employees from multiple departments or positions into new or existing departments and positions.
You perform mass organization changes by defining the changes, setting up any necessary information, and then executing the change. Based upon the definitions you enter, the Mass Organization Change process updates the affected records. This process creates Federal personnel action changes into the system as you defined them. This occurs in the same manner as if you had entered them directly online.
Mass changes affect a large number of rows of data in the system, which makes this a powerful tool. Therefore, you must give careful consideration to selecting the person in your organization who is allowed to perform mass organizational changes.
Note. If you are performing several mass change operations, assign each one a unique mass organization change ID to help you retain and identify all of them. You can group them when you set up your run process. We also recommend breaking down large changes into smaller changes to help reduce error and the burden on the system.
Before You Begin
To perform mass organization changes, you must be familiar with PeopleSoft Tree Manager. This section assumes that you know how to use PeopleTools Tree Manager.
See Also
Enterprise PeopleTools PeopleBook: PeopleSoft Tree Manager
Performing Mass Organizational Changes
Perform mass organizational changes.
Define mass changes.
Generate Mass Organization Changes
Performing Mass Organization Changes
To perform mass organization changes for positions:
(optional) Create a new department or position or make changes to an existing department or position.
Department Organizational Change |
Position Organization Change |
Note. You can access the Add/Update Position Info component from the HR: Position tree by adding a new node, (to add a new position) or double clicking on an existing node (to update an existing position). |
(optional) Recreate the hierarchy.
If you made changes to the department hierarchy, re-create it by running the Refresh Department Table (FGHR006) process from the Build Department Organization page (RUNCTL_FGHR006). |
If you've made changes to the reporting hierarchy, rebuild the position tree or position structure by running the SQR Build Position Structure (POS006A) process from the Build Position Structure page. |
Define the mass organization change on the Mass Organization Change page (GVT_MOC_DATA).
Enter the effective date of the change, the action and reason, the nature of action (NOA) and leagal authority code or codes and descriptions, and the old and new department or position.
Generate mass organization change data.
Use the Apply MOC page (RUNCTL_GVT_MASSORG) to generate mass organization changes based on the Mass Organization Change data setup. This determines which employees in the departments or positions you identified are affected and inserts new rows of Federal personnel action data.
Generate the Mass Org Exception report (FGHR034 SQR) to identify who was in an affected department or position.
If an employee wasn't processed, modify their records manually.
(position change only) Print the descriptions and/or notices.
Print the necessary position descriptions using the SQR Process FGOF8. Run a few random reports from this process to test and verify the changes that were performed.
Pages Used to Perform Mass Organizational Changes
Page Name |
Object Name |
Navigation |
Usage |
Mass Organization Change |
GVT_MOC_DATA |
Workforce Administration, Collective Processes, Mass Organization Changes USF, Define Changes, Mass Organizational Change |
Define mass changes. |
Parameters |
RUNCTL_ASOFDATE |
Workforce Administration, Collective Processes, Mass Organization Changes USF, Build Position Structure, Parameters |
Run the Build Position Structure SQR (POS006A) to link the positions in the system and create the reporting hierarchy represented in the Indented Position Report. |
Refresh Department Table |
RUNCTL_FGHR006 |
Workforce Administration, Collective Processes, Mass Organization Changes USF, Build Department Organization, Refresh Department Table |
Re-create the departmental hierarchy information for the Departments component, if you made changes to the security tree. |
Apply MOC (apply mass organization changes) |
RUNCTL_GVT_MASSORG |
Workforce Administration, Collective Processes, Mass Organization Changes USF, Apply Changes, Apply MOC |
Run the Application Engine process GVT_MASSORG to generate mass organization changes to your system data, based on the information that you entered on the Mass Organization Change page. |
Mass Org Exception Report (mass organization exception report) |
RUNCTL_FGHR034 |
Workforce Administration, Collective Processes, Mass Organization Changes USF, Mass Org Exception Report, Mass Org Exception Report |
Run this report to identify those employees that were in a position or department identified in the processed Mass Organization Change ID but who the system did not process. Modify the records of these employees manually. |
OF8 Report |
RUNCTL_FGOF8 |
Workforce Administration, Collective Processes, Mass Organization Changes USF, OF8 Report, OF8 Report |
Run this report to track position history and to verify a mass position change. |
Defining Mass Changes
Access the Mass Organization Change page.
Change
Indicate if the change is a department or position change. When you select Department, the system makes the fields in the Position Change group box unavailable. When you select Position, the system makes the fields in the Department Change group box unavailable.
Defaults
The system inserts the values you enter here into the new job data rows it creates for the employees affected by this mass organization change.
Date of Change |
Enter the date the change takes effect. The system uses this date as the effective date on the new Job Data row. |
Action and Reason Code |
Select the action and reason for the change. Note. Remember that some actions will set payroll or HR status and/or update employee dates. Review the processing or defaulting that action triggers in the system on the Actions component (ACTION_TBL). |
NOA Code (nature of action code) , WIP Status (work-in-progress status) , and Legal Authority (1). |
Select the NOA code, WIP status, and legal authority (the WIP Status and Legal Authority (1) fields are required). |
Department Change
You can add more than one row to accommodate changes to a number of departments. If you are merging two departments into one, for example, enter two rows and select one old department in one row and the other old department in the other and select the new department they are merging into in the New Department field in each row.
Old Department |
Enter the name of the department that is being changed. |
New Department |
Enter the new department name. |
Position Change
You can add more than one row to accommodate changes to a number of positions.
Old Position |
Enter the old position name. |
New Position |
Enter the new position name. |
Reports To |
Enter the position that the new position reports to. |
Generating Mass Organization Changes
Access the Apply MOC page.
Mass Organization Change Id |
Select the ID of the mass organization change that you want to process. You set up mass organization change IDs on the Mass Organization Change page. This process:
