Siebel Business Process Framework: Workflow Guide > Using Predefined Workflow Policies > Using Predefined Workflow Policy Programs for Siebel Marketing > Using a Workflow Policy Program to Send Email for a Marketing CampaignThe Send Campaign Email workflow policy program allows a marketer to send an email to the targets of the marketing campaign, such as contacts or prospects. To personalize these emails, it uses Available Substitutions in the Send Message Arguments form, such as Prospect First Name. To choose the Recipient Type, you use the Recipients list in the Workflow Policy view in the Siebel client. The campaign contacts and prospects are visible in the Contacts/Prospects list in the Campaign Administration view. Modifying Available SubstitutionsTo add a new substitution to the Available Substitutions list, you modify the SQL Statement Outputs property of the workflow policy program. To modify available substitutions
| Siebel Business Process Framework: Workflow Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
