| Siebel Customer Relationship Management Siebel Fundamentals Siebel Innovation Pack 2013, Version 8.1/8.2 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
If you want to use Microsoft Excel as your quick print application, you must change a security setting in your Web browser.
To change your Web browser's security setting to use Microsoft Excel as your quick print application
Start Internet Explorer.
Choose Tools, then Internet Options.
The Internet Options dialog box appears.
Click the Security tab.
Click the Custom Level button.
The Security Settings dialog box appears.
Under Initialize and script ActiveX controls not marked as safe, select the Prompt option button.
Click OK.
At the Internet Options dialog box, click OK.
Related Topics
