| Siebel Customer Relationship Management Siebel Fundamentals Siebel Innovation Pack 2013, Version 8.1/8.2 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
The quick print function uses your Web browser's print functionality to print the records currently shown in a list. You can also use Microsoft Excel as your quick print application. Quick print settings are defined in the User Preferences screen, then Printing view.
To set up quick print options
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
On the link bar, click Printing.
The Printing form appears.
Complete the fields as needed to set up printing the way you want it.
Some fields are described in the following table.
| Field | Description |
| General Behavior | |
| Application Menu - Print Behavior | Determines how on screen data prints when you use the application-level menu (File, then Print). (Applies only to HTML. If you use Microsoft Excel only the list will be printed.) Choose from the following options:
| Applet Menu - Print Behavior | Determines how on screen data prints when you use the menu button (Menu, then Print). Choose from the following options:
| List Behavior | |
| Print Individual Lists Using | Choose from the following options:
| Rows to Print | Choose from the following options to determine how you want rows to print:
| Columns to Print | Choose from the following options to determine how you want columns to print:
You can select Microsoft Excel as your quick print application.
To select Microsoft Excel as your quick print application
From the Print Individual Lists Using drop-down list, choose Microsoft Excel.
You can select the Web browser's print function as your quick print application.
To select the Web browser's print function as your quick print application
From the Print Individual Lists Using drop-down list, choose HTML.
Related Topics
