Siebel Hospitality Guide > Generating Event Checks > Process of Generating Event Checks >
Generating Trial Checks
When a trial check is generated, an event check total is calculated for the selected event order that includes taxes and service charges. Generating a trial check allows the operations manager to review and update order details before the final event check is generated and posted. A trial check can be generated multiple times before, during, and after the event. However, the trial check can only be generated before an event check is opened.
This task is a step in Process of Generating Event Checks.
To generate a trial check
  1. Navigate to the Service Orders screen, then the Event Order view.
  2. In the Event Orders list, query for and select the event order.
  3. In the Event form, click Trial Check.
    One or more event checks are generated for the selected order. For more information about the resulting event checks, see About Generated Event Checks.
Siebel Hospitality Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
