Siebel Object Interfaces Reference > COM Data Control Quick Reference > Object Interfaces Reference >
Property Set Methods for COM Data Control
Table 146 describes a summary of property set methods you can use with COM Data Control.
Table 146. Summary of Property Set Methods for COM Data Control
Method
Description
Format
AddChild Method for a Property Set
Adds child property sets to a property set.
Dim oPropSet as SiebelPropertySet
Dim iIndex as Integer
iIndex = oPropSet.AddChild( childObject as Property Set)
Copy Method for a Property Set
Returns a copy of a property set.
Dim oPropSet1 as SiebelPropertySet
Dim oPropSet2 as SiebelPropertySet
oPropSet2 = oPropSet1.Copy()
GetChild Method for a Property Set
Returns a child property set of a property set.
oPropSet1 = oPropSet.GetChild(index as Integer)
GetChildCount Method for a Property Set
Returns the number of child property sets that exist for a parent property set.
Dim iCount as Integer
iCount = oPropSet.GetChildCount()
GetFirstProperty Method for a Property Set
Returns the name of the first property in a property set.
Dim sPropName as String
sPropName = oPropSet.GetFirstProperty()
GetNextProperty Method for a Property Set
Returns the name of the next property in a property set.
sPropName = oPropSet.GetNextProperty()
GetProperty Method for a Property Set
Returns the value of a property.
Dim sPropVal as String
sPropVal = oPropSet.GetProperty(propName as String)
GetPropertyCount Method for a Property Set
Returns the number of properties that exist in the current level in the hierarchy.
Dim count as Long
count = oPropSet.GetPropertyCount
GetType Method for a Property Set
Returns the value of the type attribute of a property set.
Dim sTypeVal as String
sTypeVal = oPropSet.GetType()
GetValue Method for a Property Set
Returns the value of the value attribute of a property set.
Dim sValVal as String
sValVal = oPropSet.GetValue()
InsertChildAt Method for a Property Set
Inserts a child property set in a parent property set at a specific location.
oPropSet.InsertChildAt(childObject as SiebelPropertySet, index as Long)
PropertyExists Method for a Property Set
Returns a Boolean value that indicates if the property that the argument identifies exists.
Dim oPropSet as Property Set
Dim propExists as Boolean
propExists = oPropSet.PropertyExists( propName as String)
RemoveChild Method for a Property Set
Removes a child property set from a parent property set.
oPropSet.RemoveChild(index as Long)
RemoveProperty Method for a Property Set
Removes a property from a property set.
oPropSet.RemoveProperty(propName as String)
Reset Method for a Property Set
Removes every property and child property set from a property set.
oPropSet.Reset()
SetProperty Method for a Property Set
Sets a value in the property of a property set.
oPropSet.SetProperty(propName as String, propValue as String)
SetType Method for a Property Set
Sets the value for the type attribute of a property set.
oPropSet.SetType(value as String)
SetValue Method for a Property Set
Sets the value for the value attribute of a property set.
oPropSet.SetValue(value as String)
Siebel Object Interfaces Reference Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
