Table 149. Summary of Property Set Methods for the Web Client Automation Server
AddChild Method for a Property Set |
Adds child property sets to a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.AddChild(childObject as SiebelPropertySet)
Copy Method for a Property Set |
Returns a copy of a property set. |
Dim oPropSet1 as SiebelPropertySet Dim oPropSet2 as SiebelPropertySet Set oPropSet2 = oPropSet1.Copy
GetChild Method for a Property Set |
Returns a child property set of a property set. |
Dim oPropSet as SiebelPropertySet Dim oChildPropSet as SiebelPropertySet Set oChildPropSet = oPropSet.GetChild(index as Long)
GetChildCount Method for a Property Set |
Returns the number of child property sets that exist for a parent property set. |
Dim oPropSet as SiebelPropertySet Dim iCount as Long iCount = oPropSet.GetChildCount
GetFirstProperty Method for a Property Set |
Returns the name of the first property in a property set. |
Dim oPropSet as SiebelPropertySet Dim sPropName as String sPropName = oPropSet.GetFirstProperty
GetLastErrCode Method for a Property Set |
Returns the error code for the error that Siebel CRM logged most recently. |
Dim oPropSet as SiebelPropertySet Dim iErr as Long iErr = oPropSet.GetLastErrCode
GetLastErrText Method for a Property Set |
Returns the text message for the error that Siebel CRM logged most recently. |
Dim oPropSet as SiebelPropertySet Dim sText as String sText = oPropSet.GetLastErrText
GetNextProperty Method for a Property Set |
Returns the name of the next property in a property set. |
Dim oPropSet as SiebelPropertySet Dim sPropName as String sPropName = oPropSet.GetNextProperty
GetProperty Method for a Property Set |
Returns the value of a property. |
Dim oPropSet as SiebelPropertySet Dim sValue as String sValue = oPropSet.GetProperty(propName as String)
GetPropertyCount Method for a Property Set |
Returns the number of properties that exist in the current level in the hierarchy. |
Dim oPropSet as SiebelPropertySet Dim iCount as Long iCount = oPropSet.GetPropertyCount
GetType Method for a Property Set |
Returns the value of the type attribute of a property set. |
Dim oPropSet as SiebelPropertySet Dim type as String type = oPropSet.GetType
GetValue Method for a Property Set |
Returns the value of the value attribute of a property set. |
Dim oPropSet as SiebelPropertySet Dim sValue as String sValue = oPropSet.GetValue
InsertChildAt Method for a Property Set |
Inserts a child property set in a parent property set at a specific location. |
Dim oPropSet as SiebelPropertySet oPropSet.InsertChildAt(childObject as SiebelPropertySet, index as Long)
PropertyExists Method for a Property Set |
Returns a Boolean value that indicates if the property that the argument identifies exists. |
Dim oPropSet as SiebelPropertySet Dim bool as Boolean bool = oPropSet.PropertyExists(propName as String)
RemoveChild Method for a Property Set |
Removes a child property set from a parent property set. |
Dim oPropSet as SiebelPropertySet oPropSet.RemoveChild(index as Long)
RemoveProperty Method for a Property Set |
Removes a property from a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.RemoveProperty(propName as String)
Reset Method for a Property Set |
Removes every property and child property set from a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.Reset
SetProperty Method for a Property Set |
Sets a value in the property of a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.SetProperty(propName as String, propValue as String)
SetType Method for a Property Set |
Sets the value for the type attribute of a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.SetType(value as String)
SetValue Method for a Property Set |
Sets the value for the value attribute of a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.SetValue(value as String)
