Siebel Pricing Administration Guide > Siebel Pricer Technical Reference > Modifying Signals from Basic Pricing Procedure to Dynamic Pricing Procedure > Manual Signal Modifications for Communications, Media and Energy ApplicationsNOTE: If you automatically enable the Dynamic Pricing Procedure for all price lists as described in Step 2b of Switching from Basic to Dynamic Pricing Procedure, then you do not need to implement any of the modifications outlined in this topic. This topic lists the manual signal modifications required to implement dynamic pricing for Siebel Communications, Media and Energy (CME) applications. NOTE: If you are using tiered pricing, then the signals listed below should refer to Pricing Procedure - CME. CalculatePriceCMETable 73 describes the signal action, and Table 74 lists the parameters that you must modify to implement dynamic pricing for the CalculatePriceCME signal.
CalculatePriceAllCMETable 75 describes the signal action, and Table 76 lists the parameters that you must modify to implement dynamic pricing for the CalculatePriceAllCME signal.
SaveWaterfall-QuoteTable 77 describes the signal action, and Table 78 lists the parameter that you must modify to implement dynamic pricing for the SaveWaterfall-Quote signal.
SaveWaterfall-OrderTable 79 describes the signal action, and Table 80 lists the parameter that you must modify to implement dynamic pricing for the SaveWaterfall-Order signal.
SaveWaterfall-ServiceAgreementTable 81 describes the signal action, and Table 82 lists the parameter that you must modify to implement dynamic pricing for the SaveWaterfall-ServiceAgreement signal.
| Siebel Pricing Administration Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
