Siebel Product Administration Guide > Siebel Configurator Rule Assembly Language > About Operators in Rule Assembly Language >
Customizable Product Access Operators in Rule Assembly Language
Customizable Product access operators, shown in Table 38, allow you to obtain information about other areas of the customizable product. For example, you can obtain the name of an item's parent.
Table 38. Customizable Product Access Operators
Product root |
root()
Result is root of the customizable product. Takes no arguments. |
