Siebel Product Administration Guide > Product and Promotion Eligibility and Compatibility > Eligibility and Compatibility Workflow Reference >
Pricing and Eligibility Procedure - Default Workflow
Pricing and Eligibility Procedure - Default workflow will check the Eligibility and Compatibility of a Line Item and then do Pricing. This workflow is shown in Figure 19.
Figure 19. Pricing and Eligibility Procedure - Default Workflow
Workflow Description. This workflow does the following:
- Product E + C. Calls the Check Eligibility & Compatibility - Default workflow, which checks eligibility and compatibility for the Line Items.
- Pricing. Calls the Pricing Procedure - Default workflow, which prices the line items.
