Siebel Security Guide > Communications and Data Encryption > Managing the Key File Using the Key Database ManagerThis topic describes how to run the Key Database Manager utility to add new encryption keys to the key file (keyfile.bin) and to change the key file password. The AES Encryptor and RC2 Encryptor use the key in the key file to encrypt new data. The Key Database Manager automatically determines which encryptor to use (RC2 Encryptor or AES Encryptor). The Key Database Manager utility is named keydbmgr.exe on Microsoft Windows and keydbmgr on UNIX operating systems. It is located in the bin subdirectory of the Siebel Server directory. CAUTION: You must back up the key file before making changes to it. If the key file is lost or damaged, then it is not possible to recover the encrypted data without a backup key file. To run the Key Database Manager
Table 7 lists the flags and parameters for the Key Database Manager utility.
The following topics provide information on adding new encryption keys to the key file and changing the key file password: |
| Siebel Security Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
