Siebel VB Language Reference > Using Siebel VB > About Data Types > Overview of Data TypesSiebel VB is a strongly typed language. A variable can contain data only of the declared type. It supports numeric, string, record, and array data that is standard with the Visual Basic programming language. It supports the following data types:
You can do one of the following to declare a variable:
Siebel VB Language Reference | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
